vand foarte ieftin placa de baza/ram/placa video pci-e.
vand urmataorele componente pc:
>a fost un sistem,pe care l-am vandut pe bucati,fiind pc-ul surorii mele,acum plecata la facultate,si-a luat laptop,deci nu a fost overclock-ed sau alte chestii de genul,ruland mai mult pe facebook sau hi5 :))) Placa de baza Gigabyte 945gcm-s2l: Support for an Intel® Core™ 2 Extreme processor/ Intel® Core™2 Duo processor/Intel® Pentium® D processor/ Intel® Pentium® 4 processor/ Intel® Celeron® processor in the LGA 775 package (Go to GIGABYTE's website for the latest CPU support list.) Support for Intel® Hyper-Threading Technology L2 cache varies with CPU Front Side Bus (1333)/1066/800/533 MHz FSB Chipset North Bridge: Intel® 945GC Express Chipset South Bridge: Intel® ICH7 Memory 2 x 1.8V DDR2 DIMM sockets supporting up to 4 GB of system memory Dual channel memory architecture Support for DDR2 667/533/400 MHz memory modules (Go to GIGABYTE's website for the latest memory support list.) * Due to standard PC architecture, a certain amount of memory is reserved for system usage and therefore the actual memory size is less than the stated amount. Onboard Graphics Integrated in the North Bridge Audio Realtek ALC662 codec High Definition Audio 2/4/5.1-channel Support for S/PDIF Out Support for CD In LAN RTL 8111C chip (10/100/1000 Mbit) Expansion Slots 1 x PCI Express x16 slot 1 x PCI Express x1 slot 2 x PCI slots Storage Interface South Bridge: 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices iTE IT8718 chip: 1 x floppy disk drive connector supporting up to 1 floppy disk drive USB Integrated in the South Bridge Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers) Internal I/O Connectors 1 x 24-pin ATX main power connector 1 x 4-pin ATX 12V power connector 1 x floppy disk drive connector 1 x IDE connector 4 x SATA 3Gb/s connectors 1 x CPU fan header 1 x system fan header 1 x front panel header 1 x front panel audio header 1 x CD In connector 1 x S/PDIF Out header 2 x USB 2.0/1.1 headers 1 x chassis intrusion header 1 x power LED header Back Panel Connectors 1 x PS/2 keyboard port 1 x PS/2 mouse port 1 x parallel port 1 x serial port 1 x D-Sub port 4 x USB 2.0/1.1 ports 1 x RJ-45 port 3 x audio jacks (Line In/Line Out/Microphone) I/O Controller iTE IT8718 chip H/W Monitoring System voltage detection CPU temperature detection CPU/System fan speed detection CPU overheating warning CPU/System fan fail warning CPU fan speed control BIOS 1 x 4 Mbit flash Use of licensed AWARD BIOS PnP 1.0a, DMI 2.0, SM BIOS 2.3, ACPI 1.0b Unique Features Support for @BIOS Support for Download Center Support for Q-Flash Support for EasyTune Support for Xpress Install Support for Xpress Recovery2 Support for Virtual Dual BIOS Bundle Software Norton Internet Security (OEM version) Operating System Support for Microsoft® Windows Vista/XP/2000 (Go to GIGABYTE's website for operating system support information.) Form Factor Micro ATX form factor; 24.4cm x 19.3cm Placa video His hd 2400 pro: Product Code H240PRF256-R Cooler Fan GPU 2400Pro Core Clock 525 MHz Memory Clock 800 MHz Memory Size 256 MB Memory Type DDR2 Memory Interface 64 bit Interface PCI-Express x16 Box Dimension 23.2 x 16.2 x 6 cm (HxWxD) Availability Discontinued Procesor Intel pentium E2160: Essentials Status Launched Launch Date Q3'06 Processor Number E2160 # of Cores 2 # of Threads 2 Clock Speed 1.8 GHz L2 Cache 1 MB Bus/Core Ratio 9 FSB Speed 800 MHz FSB Parity No Instruction Set 64-bit Embedded Options Available Yes Supplemental SKU No Lithography 65 nm Max TDP 65 W VID Voltage Range 0.8500V-1.5V Recommended Channel Price $63.00 Graphics Specifications Integrated Graphics No Package Specifications TCASE 73.3°C Package Size 37.5mm x 37.5mm Processing Die Size 77 mm2 # of Processing Die Transistors 105 million Sockets Supported LGA775 Low Halogen Options Available No Advanced Technologies Intel® Turbo Boost Technology No Intel® Hyper-Threading Technology No Intel® Virtualization Technology (VT-x) No Intel® Virtualization Technology for Directed I/O (VT-d) No Intel® Trusted Execution Technology No AES New Instructions No Intel® 64 Yes Idle States Yes Enhanced Intel SpeedStep® Technology Yes Intel® Demand Based Switching No Thermal Monitoring Technologies Yes Execute Disable Bit Yes Placuta ram 2gb ddr2 kingstone 800mhz Pretul pachetul este de 400 ron,tiind sa amintesc cu o placa putin mai potenta nu veti avea probleme in jocuri. Predare personala buzau/rm-sarat. Trimit si prin curier,dar cu avans pentru transport. Merci pentru intelegere. Ym: bz_05_hyu Buzau,rm-sarat |
Re: vand foarte ieftin placa de baza/ram/placa video pci-e.
Se mai adauga :
Placa de baza plus procesor: >amd athlon(tm) 3200+ ~2.2ghz soccket am2 >K8M890-8237A Perfecta stare,pret 130 ron!! pomana,urgent! se mai adauga si un ram 2gb kingstone(pret pachet)= 230 ron!! pomana! Placa video SAPPHIRE HD 3450 512MB DDR2 PCI-E: 64-bit memory interface Core/Memory Clock – 600 / 500 Passive thermal solution PCI Express® 2.0 x16 bus support DirectX® 10.1 / Shader Model 4.1 support ATI CrossFireX™ multi-GPU support Unified Video Decoder (UVD) for Blu-ray™ and HD DVD at full HD 1080p HDMI with 5.1 surround sound audio (Important Information for Windows XP & Windows Vista users) Card with DUAL DVI Pret 80 ron. |
Salut.Cat costa Placa de baza Gigabyte 945gcm-s2l:?????
Salut, sunt interesat de aceasta placa, best_gemanay Id-ul meu de messenger, ne auzim acolo!
LOW e TEPAR ! Si aici si pe alte forumuri da tepe cu electronice ! MI-a vandut o placa video defecta si nu vrea sa si-o ia inapoi !
Nu mai raspunde la telefon ! NU aveti incredere , nu trimiteti prin posta si nu platiti nimic inainte ! Numarul lui de mobil este : 0769.960.521 ! Un om de nimic , care da tepe pentru 180 ron ! Pe alte site-uri foloseste ID-ul "draky90" ! http://forum.computergames.ro/223-co...50/page-2.html |
| All times are GMT +2. The time now is 12:56. |
