Kitul este nou, la cutie, bolt on (true bolt on, fara suduri, etc). KITUL NU ESTE UNIVERSAL ! MADE IN USA !
Dubla deschidere (normala si lambo).
With our Vertical Doors, Inc., kits (also known as Lambo Doors, Lambo Door Kits, Lambo Doors Conversion Kits, Lambo Door Hinges, Lambo Style Hinge Kits, LSD, VDC, VDI, VDC Kits, VLS, Upright Doors, Scissor Doors, Wing Doors, Butterfly Doors, Lamborghini Doors, etc) your ride will keep its factory look and feel while you are driving but the moment you stop and raise your doors you will experience a whole new level of attention that no other upgrade can give you.
Vertical Doors, Inc., kits are proudly made and patented in the United States. Bolt-on kits made specifically for your vehicle. VDI only manufacture's the best kits, highest quality, best customer service, strongest kits, and the most affordable kit for the quality. Our line-up includes all of the major vehicle manufactures.
This system is everything you need for a successful, reliable and cost effective conversion in a minimum amount of time.
Not only are our kit easy to install but they are also easy to operate, basically open your door like normal until it stops at a predetermined position then raise your door. You also have the option of opening your door as factory unlike most Lambo Doors, Scissor Doors, Wing Doors, Butterfly Doors, Lamborghini Doors, etc, imitators.
http://www.verticaldoors.com/audi_1999_2006_tt.html
PRET 800 euro negociabil
0722 340 642
