Go Back   Forum 4Tuning > Hobby & Pasiuni Comune > MOTO > ATV
ATV ATV-ul meu, Tuning pe ATV-uri, Vanzari-Cumparari ATV, Sfaturi utile
Old 23-04-13, 17:52   #1
broken93
broken93's Avatar
Default Vand Atv E-ton vector 250cc
Vand Atv E-ton vector 250cc din 2006, rulat foarte putin ocazional, impecabil, nici cea mai mica zgarietura,
Detalii :
Engine Type
Four cycle, Single Cylinder, Liquid cooled
Displacement 249 c.c.
Compression Ratio 10.6:1
Carburetor Kei-Hin with Manual Choke
Max. Power 22.3Nm @ 5500 rpm / 16.4bhp
Ignition C.D.I.
Battery capacity 12V-9AH; GTX12-BS
Spark Plug CR8E (NGK)
Starting Electric / Kickstart
Transmission Automatic (C.V.T. V-belt) Manual Shift - Forward/Reverse
Front Suspension
Dual A-Arm Adjustable Shock @ 2.95" Travel
Rear Suspension
Swing Arm Adjustable Shock @ 4.72" Travel
Front Brake Hydraulic Disc (2)
Rear Brake Hydraulic Disc
Front Tire 21x7-10
Rear Tire 22x11-9
Overall Dimensions
Length x Width x Height
70.1 x 40.6" x 44.9"
Wheelbase 46.9"
Dry Weight 441 lbs
Seat Height 35"
Ground Clearance 5.9"
Maximum Rider Weight 330 lbs
Fuel Tank Capacity 12 liters / 3.17 Gal
Color
Blue
Optional Features
Rear Cargo Rack (optional)
Headlights
Inmatriculat, acte la zi, fiscal pe loc, este in stare foarte buna fiind aproape nou rulat foarte putin .
Pret 1650 euro. 0769632711 fara variante .
ID:	2756963   Click image for larger version
ID:	2756964   Click image for larger version
ID:	2756966   Click image for larger version
ID:	2756967   Click image for larger version
ID:	2756969   Click image for larger version
ID:	2756970   Click image for larger version
broken93 is offline   Reply With Quote
Old 24-04-13, 13:09   #2
broken93
broken93's Avatar
Default Re: Vand Atv E-ton vector 250cc
Pretul scade la 1000 euro fix pana sambata, daca nu se da pana sambata revine la 1500 neg.
Old 28-04-13, 23:44   #3
broken93
broken93's Avatar
Up valabil in continuare si negociabil !
Old 04-05-13, 01:23   #4
broken93
broken93's Avatar
Valabil in continuare !
