Vand Atv E-ton vector 250cc
10 Attachment(s)
Vand Atv E-ton vector 250cc din 2006, rulat foarte putin ocazional, impecabil, nici cea mai mica zgarietura,
Detalii : Engine Type Four cycle, Single Cylinder, Liquid cooled Displacement 249 c.c. Compression Ratio 10.6:1 Carburetor Kei-Hin with Manual Choke Max. Power 22.3Nm @ 5500 rpm / 16.4bhp Ignition C.D.I. Battery capacity 12V-9AH; GTX12-BS Spark Plug CR8E (NGK) Starting Electric / Kickstart Transmission Automatic (C.V.T. V-belt) Manual Shift - Forward/Reverse Front Suspension Dual A-Arm Adjustable Shock @ 2.95" Travel Rear Suspension Swing Arm Adjustable Shock @ 4.72" Travel Front Brake Hydraulic Disc (2) Rear Brake Hydraulic Disc Front Tire 21x7-10 Rear Tire 22x11-9 Overall Dimensions Length x Width x Height 70.1 x 40.6" x 44.9" Wheelbase 46.9" Dry Weight 441 lbs Seat Height 35" Ground Clearance 5.9" Maximum Rider Weight 330 lbs Fuel Tank Capacity 12 liters / 3.17 Gal Color Blue Optional Features Rear Cargo Rack (optional) Headlights Inmatriculat, acte la zi, fiscal pe loc, este in stare foarte buna fiind aproape nou rulat foarte putin . Pret 1650 euro. 0769632711 fara variante . |
Re: Vand Atv E-ton vector 250cc
Pretul scade la 1000 euro fix pana sambata, daca nu se da pana sambata revine la 1500 neg.
Up valabil in continuare si negociabil !
Valabil in continuare !
| All times are GMT +2. The time now is 19:53. |
