Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Electrice si Electronica
Old 27-12-08, 14:09   #1
nutzuXXL
nutzuXXL's Avatar
[SEAT]
Exclamation VAG-COM USB 409.1 (KKL DUAL Line) interfata diagnoza
VAG-COM USB (KKL DUAL Line)
The unit Reads and Clears codes for most VW/Audi/Seat/Skoda vehicles. (1994 through to 2005)
This cable interface is fully compatible with diagnostic software version 409.1 and older from VAG.
Save on all the expensive garage bills by diagnosing your cars faults yourself.
This diagnostic cable is usable for ISO9141 and KWP2000 transmission protocols.
Whats Included:
*VAG COM USB scanner
*Software CD
Functions:
Using the hardware you are able to communicate to your cars control modules.Each car can have lots of control modules (cars on board computers), which our hardware software can talk to, the number and type of modules available will vary based on your cars make and model. Please note this is a well known product in the car industry as is one of the most widely used car diagnostic software by mechanics.
Reference Data:
1.This cable can not work if your car uses a protocol/bussystem like VPW, PWM or CAN-bus.
2. Terminal K = Bus of communication
3. Terminal L = Ignition for waking up car computing system (ECU: Engine Control Unit)
4. Existed 3 different protocols with same OBD2 connector incl. ISO/KWP, VPW, PMW
5. This K/L Diagnostic interface & cables work on ISO/KWP (Key Word Protocol) launched after 1996 only
6. Supported also ISO9141 protocol
7.The Cables may work with some versions of the Carsoft, but carsoft used a lot of different interfaces during the different versions and also had some custom interfaces.
Tool Description:
1. Engine Diagnostics
2. Clear DTC (error) code, over 7500 DTC codes with description
3. Reset Service lights
4. Read & Clear Airbag fault Codes
5. Read & Clear ABS Faults
6. Automatic Transmission
7. Immobiliser / Alarm Systems
8. Car Stereo System
9. Central Locking System
10. and lots more...
Will This Code Reader Work with My Car :
The cable is specially designed to work with most models sold Worldwide of 1990 or newer models. If a model has a 16-pin "OBD-II style" Data Link Connector(DTC) which is not CAN BUS protocol, the cable/software will certainly work. If it has an old-style 2x2 Data Link Connector(DTC), then it depends on whether there are 4 or 3 wires connecting to the pins. If there are 4 wires, with each going to each pin, then it will work; If there are only 3 wires, leaving one pin disconnected, then it will not work.
For models with old-style 2x2 Data Link Connector(DTC), you need to have a 2x2 cabling adapter which is not included in this product package, but can be bought
compatibil cu toate masinile vag (skoda , seat vw , audi) din '95-'04-'05
am mai multe bucati noi sigilate
pret 90Ron
trimit si prin posta 95 ron cu tot cu transport
nutzuXXL is offline
Old 30-12-08, 14:56   #2
nutzuXXL
nutzuXXL's Avatar
[SEAT]
Default Re: VAG-COM USB 409.1 (KKL DUAL Line) interfata diagnoza
up
mai vand si un kwp2000plus cu file tuning si originale pt majoritatea automobilelor din 1990-2005
nutzuXXL is offline
Old 09-01-09, 13:09   #3
nutzuXXL
nutzuXXL's Avatar
[SEAT]
up...........
niste poze
si un link cu detalii despre kwp2000plushttp://ucables.com/ref/KWP2000
ID:	748465   Click image for larger version
ID:	748466   Click image for larger version
nutzuXXL is offline
Old 12-01-09, 10:07   #4
nutzuXXL
nutzuXXL's Avatar
[SEAT]
up . mai am 1 bucata vag-com 409.1
pretul la kwp2000+ (cu filele tuning/originale incluse) este de 440 ron negociabil pt cei cu adevarat interesati . urgent ca am nevoie de bani
trimit si prin fancourier in tara
nutzuXXL is offline
Old 20-03-09, 19:35   #5
nutzuXXL
nutzuXXL's Avatar
[SEAT]
up cablu obdII + soft vag-com 409.1 si soft pt diagnoza renault la 100ron
nutzuXXL is offline
Old 22-11-10, 13:11   #6
nutzuXXL
nutzuXXL's Avatar
[SEAT]
acum am
vag-com 10.6 pret190ron
vag tacho 3.01 pret150ron
op-com 1.39 pret 190ron
contact 0751 024 563
nutzuXXL is offline
Old 24-11-10, 20:31   #7
gusti78
merge sa faca orice pe logan din 2007?
ce contine pachetul?
daca am si gpl montat after market poate citi si erorile pe gpl sau face modificari?(landi renzo-omegas)
Gusti
gusti78 is offline
Old 25-11-10, 08:23   #8
nutzuXXL
nutzuXXL's Avatar
[SEAT]
am doar
409 nu mai aduc
nutzuXXL is offline
Old 02-12-10, 19:20   #9
nutzuXXL
nutzuXXL's Avatar
[SEAT]
vag tacho + opel immo 3.01 pret150ron
nutzuXXL is offline
Old 18-12-10, 12:45   #10
nutzuXXL
nutzuXXL's Avatar
[SEAT]
se poate inchide . nu mai este valabil
nutzuXXL is offline
