Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 18-06-08, 11:01   #1
elspa
elspa's Avatar
Default KIT Turbo VW VR6 StreetDemon 375HP - cel mai complet kit posibil
PRET 1150 euro
Livrare 10-14 zile
Avans 50%.
Aplicatie pana la 375 cp.
Cel mai complet kit posibil.
VW GOLF JETTA WITH VR6 ENGINE
VW CORRADO MKIII VR6 ENGINE
WILL FIT ALL VW WITH VR6 MOTOR!
T3/T4 TURBO CHARGER
3 INCH AIR INTAKE SIDE - 2 INCH EXHAUST EXIT SIDE - 30+ PSI CAPABLE
T3/T4 FLANGE FITTING - T04E HYBRID TURBO CHARGER - .57 COMPRESSOR WHEEL TRIM
.50 A/R COMPRESSOR - .63 A/R TURBINE - RELIABLE AND DEPENDABLE PERFORMANCE
HIGH QUALIY - FAST SPOOL - TURBO MANIFOLD T3 FLANGE
SINGLE PIECE DESIGN - QUICK SPOOLING DESIGN - HIGH STRENGHT
SMOOTH PORTS AND FINNISHED TO SUPPORT HIGH HORSE POWER - WILL NOT CRACK EASILY
SUPER THICK MATERAL IS HEAT TEST AND STRESS TESTED - BOLT ON MANIFOLD!
HIGH FLOW TURBO INTERCOOLER
SIZE : 28" X8" X 2.5" WITH 2.5' INCH INLET/OUTLET
LOW PRESSURE DROP - LARGE COOLING AREA - EASY INSTALL - TUBE AND FIN STYLE INTERCOOLER
POLISHED AND SHAPED END TANKS ADD TO GREAT LOOK OF BODY KIT
38 MM TURBO WASTE GATE
INCLUDES HARD WARE AND GASKETS AND BOLTS AS SHOWN FOR EASY INSTALL
EFFICIENT DESIGN - SMOOTH OPERATION - DEPENDABLE PERFORMANCE
NEW DESIGN IS SUPERIOR TO OTHER WASTEGATES ONLY USE THE BEST
LOWER THE CHANCE OF FAILURE WITH HIGH QUALITY DIAPHRAM AND INTERNALS
T3/T4 5 BOLT DOWN PIPE FLANGE + GASKET
THIS IS PROVIDED SO YOU CAN MAKE YOUR OWN DOWN PIPE
SHOULD BE ABOUT 50-100.00 TO GET YOUR DOWN PIPE MADE AT
LOCAL MUFFLER SHOPS
TURBO PIPING / INTERCOOLER PIPING KIT - 6061 ALUMINUM
2.5 INCH DIAMETER PIPING KIT WITH RUBBER COUPLERS AND BOLT CLAMPS
MANDREL BEND FOR HIGH FLOW AND HIGH HORSE POWER
PIECES SHOW ARE VERY FLEXIBLE AND WILL BE ABLE TO FIT MOST CARS
THEY MAY NEED TO BE CUT OR BENT TO FIT YOUR CAR
PULL TYPE BOV
AWESOME SOUND - CNC BILLET ALUMINUM - DUAL STAGE HANDLE HIGH BOOST POWER
FAST RESPONSE - TWO STAGE TYPE BLOW OFF - ONE FOR LOW AND HIGH BOOST PRESSURE
INCLUDE BOLT ON FLANGE PIPE 2.5 INCH - RUBBER GASKET - T FITTING AND CLAMPS
BOOST CONTROLLER
control boost pressure of your turbo kit - from 1-30 psi - adjust power at your finger tips
RELIABLE ADJUSTER WE USE ON OUR OWN CAR ABLE TO SET BOOST LEVEL
OIL FEED LINE + RESTRICTOR FOR TURBO
USE THIS OIL RESTRICTOR TO PREVENT SEAL BLOW OUTS
TOO MUCH OIL PRESSSURE CAN CAUSE TURBO TO FAILURE
0722 340 642
ym: mihai_spanachi
ID:	566364   Click image for larger version
ID:	566365   Click image for larger version
ID:	566367   Click image for larger version
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 02-07-08, 09:55   #2
elspa
elspa's Avatar
Default Re: KIT Turbo VW VR6 StreetDemon 375HP - cel mai complet kit posibil
sus cu ele......
Old 05-07-08, 01:10   #3
elspa
elspa's Avatar
up................................
Old 14-07-08, 18:56   #4
KENZO
KENZO's Avatar
[Pole Position Racers]
Pt un renault clio 1 1,8 16 v poti aduce kitt turbo complect?si la cati cai o duc daca poti procura
KENZO is offline   Reply With Quote
Old 14-07-08, 20:10   #5
elspa
elspa's Avatar
ti-am raspuns si pe alt thread
Old 13-08-08, 09:46   #6
elspa
elspa's Avatar
up........
Old 24-08-08, 12:10   #7
elspa
elspa's Avatar
http://www.srz.ro/pagini/Kituri%20turbo%20complete.htm
Old 22-09-08, 14:50   #8
elspa
elspa's Avatar
up......
Old 15-10-08, 00:12   #9
elspa
elspa's Avatar
up......
Old 12-11-08, 07:59   #10
elspa
elspa's Avatar
up.......
- Copyright 2025 4Tuning -
