Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 17-06-08, 01:17   #1
elspa
elspa's Avatar
Default KIT Turbo BMW e36 320, 323, 328, 330 StreetDemon 375HP - 1150 euro
PRET 1150 EURO
LIVRARE 10-14 ZILE
Turbina SPA Turbo.
Cel mai compelt kit de upgrade posibil
PRET 1150 euro
livrare 10-14 zile
avans 50%
Brand new “Street Demon” Series turbo package for e36 6 cylinder. The most complete turbo package available for the BMW platform. This package has all new quality parts that are capable of producing well beyond 375 horsepower at 25 PSI with supporting modifications and a built motor. This is the most complete package available compared to others at an affordable price. Works with either automatic or manual gear boxes. The turbocharger connects the exhaust via down pipe which might be required. Lastly, this kit keeps your air conditioning and power steering for a great street setup.
(1) Hybrid Turbo Charger:
T3/T4 hybrid
Oil fitting gaskets & mounting studs included
3" inlet diameter with a 2" outlet
wet float bearings & properly balanced
1/8 NPT oil inlet
.50 A/R compressor housing
.63 A/R turbine housing
.57 compressor wheel trim mapped for low & high boost setups
Capable of producing over 450 horsepower
(1) Turbo Exhaust Manifold:
High quality tubular piping with large primaries
High quality T3 turbocharger flange
Extra thick flange support the turbo well
Fully ported and polished design
TIG welded 321 Stainless steel material for longevity & strength
Strong design supports the weight of the turbo
Full install kit includes all bolts & hardware
Beautifully polished for a show finish
High quality gaskets included for turbo flange & exhaust manifold flange
(1) Front Mount Intercooler:
Large design cools down the turbocharged air efficiently
Extra thick core provides ample cooling
Lightweight aluminum racing intercooler
Strong TIG welds will support high PSI levels
2.5" cold outlet & 2.5" hot inlet
Less then 2% pressure drop
(1) Universal Intercooler Piping Kit:
Lightweight aluminum piping
Might require modification to fit
(2) straight 2.5” pipes”
(6) 90 degree 2.5“ J bends
(4) 90 degree 2.5” tight bends
(24) stainless steel high strength worm gear clamps
( 2.5” straight silicone couplers
(4) 2.5” 90 degree silicone couplers
(1) Boost Controller:
Control your boost with a precise click
Can be adjusted for any PSI level desired
Can be setup to adjust boost PSI on the fly
CNC machined design
Anodized aluminum finish
Includes complete install kit
(1) Blow Off Valve:
Quality design will not leak under high boost conditions
Performance design produces a powerful & aggressive sound
Flanges installed at user discretion
Protects turbo by letting pressure surges vent when shifting and/or reducing throttle
ID:	565377   Click image for larger version
ID:	565378   Click image for larger version
ID:	565380   Click image for larger version
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 27-06-08, 22:30   #2
elspa
elspa's Avatar
Default Re: KIT Turbo BMW e36 320, 323, 328, 330 StreetDemon 375HP - 1150 euro
sus cu ele........
Old 16-07-08, 09:51   #3
elspa
elspa's Avatar
sus cu ele....
Old 09-08-08, 13:25   #4
nutzu4pub
nutzu4pub's Avatar
merge pus pe e36 318 is?si pana la cati cai il duce?
nutzu4pub is offline   Reply With Quote
Old 09-08-08, 16:27   #5
elspa
elspa's Avatar
pot aduce si kitul pentru 318is, costa cu 110 euro mai mult, si il duce fara schimbari interne la 230-240 cp
Old 13-08-08, 09:51   #6
elspa
elspa's Avatar
up.........
Old 24-08-08, 12:10   #7
elspa
elspa's Avatar
http://www.srz.ro/pagini/Kituri%20turbo%20complete.htm
Old 09-09-08, 10:00   #8
elspa
elspa's Avatar
up,.......
Old 09-09-08, 21:28   #9
Alexxxx
Alexxxx's Avatar
Salut! M-ar iunteresa un kit turbo pentru un Bmw E36 320i din 1996!As vrea sa stiu ce contine kitul, o putere estimativa cu interne stock si cat m-ar costa!
Alexxxx is offline   Reply With Quote
Old 09-09-08, 23:53   #10
elspa
elspa's Avatar
ai ce contine mai sus, cu internele stoc din motor cam 230 cp, costa 4200 ron.
Old 12-09-08, 22:27   #11
No-X-Cape
No-X-Cape's Avatar
ptr e36 325i 192HP din 93 ....kitul costa 1150E ? cati cai dezvolta fara schimbat interne cu motorul stock ?multumesc
No-X-Cape is offline   Reply With Quote
Old 13-09-08, 00:30   #12
elspa
elspa's Avatar
280-300 si costa 1150 euro
Old 22-09-08, 14:33   #13
elspa
elspa's Avatar
up.......
Old 12-11-08, 07:55   #14
elspa
elspa's Avatar
up.....
Old 04-12-08, 11:58   #15
elspa
elspa's Avatar
up.....
- Copyright 2025 4Tuning -
