PRET 1150 EURO
LIVRARE 10-14 ZILE
Turbina SPA Turbo.
Cel mai compelt kit de upgrade posibil
PRET 1150 euro
livrare 10-14 zile
avans 50%
Brand new “Street Demon” Series turbo package for 1997 - 2006 Audi / Volkswagen 1.8L 20v powered vehicles. The most complete turbo package available for the Audi and VW platform. This package has all new quality parts that are capable of producing well beyond 495 horsepower at 25 PSI with supporting modifications and a built motor. This is the most complete package available compared to others at an affordable price. On a stock motor the kit will add over 100 horsepower on a low boost setting of 8 PSI. Also, the included electronic turbo timer provides a hassle-free operation of precisely calculating the cool down period to ensure a proper cool down for your turbocharged motor. Works with either automatic or manual gear boxes. The turbocharger connects the exhaust via down pipe which might be required. Lastly, this kit keeps your air conditioning and power steering for a great street setup.
(1) Hybrid Turbo Charger:
T3/T4 hybrid
Oil fitting gaskets & mounting studs included
3" inlet diameter with a 2" outlet
wet float bearings & properly balanced
1/8 NPT oil inlet
.50 A/R compressor housing
.63 A/R turbine housing
.57 compressor wheel trim mapped for low & high boost setups
Capable of producing over 450 horsepower
(1) Turbo Exhaust Manifold:
High quality tubular piping with large primaries
High quality T3 turbocharger flange
Extra thick flange support the turbo well
Fully ported and polished design
TIG welded 321 Stainless steel material for longevity & strength
Strong design supports the weight of the turbo
Full install kit includes all bolts & hardware
Beautifully polished for a show finish
High quality gaskets included for turbo flange & exhaust manifold flange
(1) Front Mount Intercooler:
Large design cools down the turbocharged air efficiently
Extra thick core provides ample cooling
Lightweight aluminum racing intercooler
Strong TIG welds will support high PSI levels
2.5" cold outlet & 2.5" hot inlet
Less then 2% pressure drop
(1) Universal Intercooler Piping Kit:
Lightweight aluminum piping
Might require modification to fit
(2) straight 2.5” pipes”
(6) 90 degree 2.5“ J bends
(4) 90 degree 2.5” tight bends
(24) stainless steel high strength worm gear clamps
2.5” straight silicone couplers
(4) 2.5” 90 degree silicone couplers
(1) Boost Controller:
Control your boost with a precise click
Can be adjusted for any PSI level desired
Can be setup to adjust boost PSI on the fly
CNC machined design
Anodized aluminum finish
Includes complete install kit
(1) Blow Off Valve:
Quality design will not leak under high boost conditions
Performance design produces a powerful & aggressive sound
Flanges installed at user discretion
Protects turbo by letting pressure surges vent when shifting and/or reducing throttle
(1) Slim Cooling Fan:
Slim design provides excellent engine bay clearance
Creates additional aftermarket cooling
Reversible design can either pull or push air
Includes the mounting tabs for a easy zip tie install
Superior flow of a curved-blade design
Versatility of a push/pull reversible fan
1.25" thick outside perimeter
2.50" thick inside perimeter
Fan can be used to cool: A/C condenser, oil or transmission cooler, mounting on an intercooler to prevent heat soak, or cooling a a2w radiator
(1) Electronic Turbo Timer:
Mounted inside the vehicle for on the fly adjustments
Bright Easy to read LED Digital Display
Auto mode feature creates a hassle-free operation
Includes pigtail wiring and extra wiring for ease of installation
Precisely calculates the cool down period for the motor
Ensures a proper cool down for your turbocharged car every time
Important to preventing premature turbo wear and failure
Increases turbocharger's operating lifespan
Failure to reduce the temperature of the turbo could result in "coking" of oil inside the turbo
Coking is the baking of oil, turning it into a grimy substance
(1) 35mm Wastegate:
V-band clamp style
Anodized show like finish
Protect the turbo system from over boosting
(1) Fuel Pressure Regulator:
Precision pressure gauge
Fully adjustable
Great to setup fuel pressure for boosted engines
(1) Catch Can:
Stops excess oil from blowing to the intake manifold
Removes oil vapors from breather line
Ensures better mileage & better performance
Show like high quality polish
0722 340 642
www.srz.ro
ym: mihai_spanachi
