Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 21-07-11, 18:07   #1
elspa
elspa's Avatar
Default Kit AIS Methanol Injection stage 1 - 200 euro
folosit foarte putin, made in USA.
Are dual nozzle upgrade.
pret 210 euro.
0722 340 642
ym: mihai_spanachi
http://www.alcoholinjectionsystems.c...duct_info.html
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 22-07-11, 17:23   #2
AudioClass
Ford Driver
AudioClass's Avatar
Default Re: Kit AIS Methanol Injection stage 1 - 200 euro
Are si rezervor, sau fara?
AudioClass is offline   Reply With Quote
Old 22-07-11, 18:03   #3
elspa
elspa's Avatar
fara, e exact kitul din link
Old 18-08-11, 03:52   #4
Bik3rBoy
Bik3rBoy's Avatar
Merge pe motoare turbo diesel ?
Bik3rBoy is offline   Reply With Quote
Old 18-08-11, 11:18   #5
elspa
elspa's Avatar
e vandut, dar am in oferta si pentru motoare diesel.
http://www.srz.ro/pagini/WaterAlcoholInjection.htm
DEVILS OWN STAGE 1 - MOTOARE TURBO DIESEL
- kit complet universal pentru orice motor turbodiesel
- reduce riscul aparitiei detonatiilor la 0
- reducere temperatura in admisie cu 50-250 grade
- reduce temperatura aerului in cilindru cu 300+ grade
- crestere a puterii cu 15-30%
- mareste cifra octanica a combustibilului cu 8-20 puncte
- pompa 250 psi cu garnituri rezistente la alcool
- switch boost adjustabil de la 1-25 psi
- made in USA
PRET 300 EUR
DEVILS OWN STAGE 2 - MOTOARE TURBO DIESEL
- crestere a puterii cu 25-45%
- mareste cifra octanica a combustibilului cu 8-20 pcte
- sistemul asigura o crestere progresiva a fluxului de apa/alcool in conjuctie cu cresterea boost-ului
- controller progresiv al fluxului de apa/alcool 0-5 volts ( TPS, MAF, MAP, EGT, AIT)
- panou de control
- made in USA
PRET 400 EUR
DEVILS OWN STAGE 2 EGT - MOTOARE TURBO DIESEL
- controller progresiv al fluxului de apa/alcool prin sonda EGT
- panou de control cu convertor sonda EGR
- 3 injectoare
- made in USA
PRET 520 EUR
Old 18-08-11, 18:28   #6
sorcer
la un 1.5 dci (logan) de 65 cp remapat ar avea ceva efect kitul DEVILS OWN STAGE 2 - MOTOARE TURBO DIESEL ? sau il pun absolut degeaba?
sorcer is offline   Reply With Quote
Old 18-08-11, 18:52   #7
elspa
elspa's Avatar
undeva la 15 cp.
poti vb cu userul felix despre avantajul pe dci, el a avut pe logan.
Old 18-08-11, 18:54   #8
sorcer
undeva la 15 cp.
pai suna foarte bine ca atunci ajung la aproape 100 cai , si chiar daca nu vre-o 90 tot ar trebui sa fie remapare+kitul de la tine .
