Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 06-07-11, 21:53   #1
elspa
elspa's Avatar
Default Boost Controller electronic Turbosmart e-Boost STREET 40psi - cel mai profi
Folosit foarte putin (nu are urme de utilizare), pachet complet, cam cel mai destept boost controller de pe piata, functie de mentinere a boost-ului pana la turatii inalte (Boost Correction Factor: eliminates boost drop off at high RPM)
pret 900 ron.
0722 340 642
Part Number: TS-0302-1002
Accessories: TS-0302-2001 – eBS Mounting Bracket
Spare Parts: TS-0302-3002 – eBS Re-Loom kit
Racing technology for the street
E-Boost STREET is an electronic boost controller aimed at the street performance market. It features many boost control capabilities found on its big brother – the e-Boost2, continuing the e-Boost tradition of providing class-leading boost control, value for money and no nonsense features.
New features include 40psi max boost operating pressure and an auxillary output.
2 Boost Settings: easily selected via the “turn-and-push” button. An external switch can also be used to change between boost groups if required.
Boost Correction Factor: eliminates boost drop off at high RPM.
3 Segment Display: with adjustable brightness can be configured for PSI, KPa, or BAR and will flash when warning of over boost shutdown or rev limit, allowing the unit to be used as a boost gauge, tachometer, or a shift light.
Dimensions: W:80mm H: 25mm D: 95mm (can mounted within a 1/4 DIN size opening)
Maximum Boost Level: 40PSI / 2.72BAR.
What’s in the box: e-Boost STREET control unit. Wiring loom + installation kit
Solenoid with mounting bracket and vacuum fittings, vacuum hose and hose clamps
Sablare si PowderCoating - reconditionari jante, etrieri, etc
Da-ne un like pe Facebook
https://srzpowdercoating.ro
https://www.facebook.com/SRZPowdercoatingCustoms
elspa is offline   Reply With Quote
Old 07-07-11, 13:17   #2
elspa
elspa's Avatar
Default Re: Boost Controller electronic Turbosmart e-Boost STREET 40psi - cel mai profi
vandut
