Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Turbine & Blow Off
Old 08-02-06, 11:41   #1
hit-man
hit-man's Avatar
Default cumpar blow-off valve twin piston
veniti cu oferte daca imi convine facem targul
Std type diaghragm valves will not work as they introduce an air leak due to the nature of the design, as the Escort RS Turbo has a metering unit it cannot and will not run if it has an air leak of this size.
The twin piston valve has a secondary circuit to block the air leak if there is no positive pressure present.
2002 Citroen C5 2.0 HDi (White Whale)
hit-man is offline   Reply With Quote
Old 08-02-06, 11:57   #2
bogdan
Vice Presedinte Speedline Motorsport
bogdan's Avatar
[A.C.S. Speedline Motorsport]
ce vrei sa spui cu citatul?
bogdan is offline   Reply With Quote
Old 08-02-06, 12:00   #3
hit-man
hit-man's Avatar
adik numai alea twin piston merg
Old 08-02-06, 12:01   #4
bogdan
bogdan's Avatar
ai incercat cu alt ceva si nu merge?
Old 08-02-06, 12:14   #5
sevi
sevi's Avatar
Difera escortul de 220 fata de sierra 204, are vacumurile puse altfel. Am citit p e net.
sevi is offline   Reply With Quote
Old 08-02-06, 12:37   #6
bogdan
bogdan's Avatar
ai citit degeaba el tocmai a spus ca are un RS turbo nu un escort cosworth dar mai citeste
Old 08-02-06, 16:23   #7
sevi
sevi's Avatar
Adica?
Fii mai explicit. Care e unu si care altu? DPDV al BOV-ului?
Old 10-02-06, 21:15   #8
hit-man
hit-man's Avatar
adika aia simpla e cu diafragma de cauciuc sia aialalta e cu pistonashe
Old 24-05-06, 02:30   #9
hit-man
hit-man's Avatar
Default Re: cumpar blow-off valve twin piston
up..............
Old 05-07-06, 11:58   #10
hit-man
hit-man's Avatar
uppppppppppp urgent
Old 06-07-06, 19:48   #11
hit-man
hit-man's Avatar
up.................
Old 07-07-06, 02:36   #12
STIprdr
Dream Squad Member
STIprdr's Avatar
[Dream Squad]
[Honda]
hit man vezi pm!
STIprdr is offline   Reply With Quote
Old 07-07-06, 03:33   #13
GTA
GTA's Avatar
Hai sa-ti spun o treaba cu BOV-urile.....eu am o Calibra Turbo.....si am schimbat vreo 4 BOV-uri pana acum printre care 2 twin piston de Subaru STI.............pana nu mi-am comandat exact pentru motorul meu nu mi-a mers nici una........asa ca ai grija ce cumperi.........Eu mi-am comandat de la FORGE MOTORSPORT un BOV twin piston si functioneaza impecabil(150E).
GTA is offline   Reply With Quote
Old 28-07-06, 21:45   #14
hit-man
hit-man's Avatar
up.................
Old 31-07-06, 10:03   #15
hit-man
hit-man's Avatar
up.....................
