Piese auto Audi A4 B6, generatia a 2-a 2000 - 2008 (Typ 8E/8H) motorizari 3.0 TDI PD, 2.5 TDI PD, 2.0 TDI PD, 1.9 TDI PD | CTdez
CTdez va ofera piese auto second hand la cele mai bune preturi de pe piata cu cele mai prompte servicii din bransa.
Oferim curierat rapid in toata tara cu livrare a 2-a zi.
Motorizari disponibile:
- 1.9 TDI PD (diesel / motorina), putere: 130cp / 96kw, tip motor: AVB si AWX;
- 2.0 TDI PD (diesel / motorina), putere: 140cp / 103kw, tip motor: BLB;
- 2.5 TDI PD (diesel / motorina), putere: 180cp / 132kw, tip motor: AKE;
- 3.0 TDI PD (diesel / motorina), putere: 204cp / 150kw, tip motor: BKN;
Caroserie:
- Sedan / Berlina (4-door sedan)
Dotari:
- cutie de viteze manuala 5+1 trepte si 6+1 trepte, cutie de viteze automata / hidramata tiptronic si cutie de viteze semiautomata DSG, ABS, ESP, geamuri electrice fata, geamuri electrice spate, centralizare, clima / aer conditinat A/C, servodirectie hidraulica.Piese in stoc:
Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi;
Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere;
Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela;
Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta;
Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei;
Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager;
Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera;
Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara;
Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum;
Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate;
