Dezmembrez Opel Vectra C 1.9 CDTi, 2.0 DTi, 3.0 CDTi, caroserie hatchback si caravan,
Motorizari :
- 1.9 CDTi 74kw (101cp) tip Z19DTL
- 1.9 CDTi 88kw (120cp) tip Z19DT
- 1.9 CDTi 110kw (150cp) tip Z19DTH
- 2.0 DTi 74kw (101cp) tip Y20DTH
- 3.0 CDTi 130kw (177cp) tip Y30DT
Dotari: cutie automata tiptronic, cutie manuala 5+1 si 6+1 trepte, ABS, ESP, 8X Airbag, Jante tabla si aliaj R15, R16, R17 si R18, CARLIG DE REMORCARE, interior textil, piele neagra si piele crem, rulou portbagaj, proiectoare ceata, CD Player OEM CDR 2005, Mp3 Player CD30, oglinda interior heliomata, senzori ploaie si de lumina, Clima si Aer Conditionat A/C.
Tel: 0723364267
Ym :
constantadezmembrari@yahoo.com
Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi;
Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere;
Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela;
Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta;
Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei;
Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager;
Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera;
Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara;
Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum;
Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate;
