Dezmembrez Audi A4 (B5) caroserie sedan 1.6i, 1.8i, 1.8T, 1.9 TDI, 1.9 TDI PD, 2.5 TDI, an fab 1994-2001,
- 1.6i 74kw (101cp) tip AHL,
- 1.8i 92kw (125cp) tip ADR, APT. ARG
- 1.8T 110kw (150cp) tip APU, AEB, ANB, AWT
- 1.9 TDI 81kw (110cp) tip AFN si 66kw (90cp) tip AHU,
- 1.9 TDI PD 85kw (115cp) tip AJM,
- 2.5 TDI 110kw (150cp) tip AFB si AKN.
Dotari: transmisie fata si QUATTRO, cutie de viteze manuala 5+1, 6+1 trepte si automata tiptronic, suspensie standard si SPORT, ABS, Aer Conditionat A/C si Climatronic, geamuri si oglinzi electrice, instalatie GPL secventiala cu butelie toroidala, jante tabla si aliaj R15, R16, R17 si R18.
Tel: 0723364267
Ym :
constantadezmembrari@yahoo.com
Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi;
Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere;
Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela;
Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta;
Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei;
Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager;
Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera;
Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara;
Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum;
Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate;
