CTdez va ofera piese auto second hand cela mai bune preturi de pe piata cu cele mai promte servicii din bransa.
Oferim curierat rapid in toata tara, comanda va ajunge la dvs a 2-a zi dupa ce a fost plasata.
Ne puteti contacta oricand telefonic sau prin email.
Tel: 0765495934
Email: contact@ct*******
Dezmembrari auto VW Passat B5 si B5.5 (Typ 3B/3BG) 1996 - 2005
Motorizari disponibile:
- 1.8i tip ADR, 125cp / 92kw
- 1.8T tip APU, 150cp / 110kw
- 1.9TDI tip AFN, 110cp / 81kw
- 1.9 TDI PD tip AJM, 115cp / 85kw
- 1.9 TDI PD tip AVF, 130cp / 96kw
- 2.5 TDI tip AFB si AKN, 150cp / 110kw
Caroserie: Break si Sedan
Dotari: cutii manuale si automate Tiptronic, bara fata cu spalator faruri, faruri xenon fabrica, jante tabla R15, oglinzi si geamuri electrice, cotiera piele, interior piele crem, volan sport 3 spite, carlig de remorcare, ABS, ASR, cruise control
Piese in stoc:
Elemente de caroserie: aripa fata, capota motor, capota portbagaj, hayon, bara fata, bara spate, portiera, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi;
Elemente optice: luneta, far, oglinda electrica, oglinda manuala, semnalizator, stop / lampa / tripla, parbriz, geam portiere;
Anexe motor: compresor aer conditionat, alternator, chiuloasa, bloc motor, baie ulei, pompa servodirectie, turbosuflanta, galerie admisie / evacuare, electromotor, pompa benzina / motorina, piston, pompa injectie, suport motor, electrovalva, vibrochen, pompa ulei, injector, biela;
Elemente de directie / suspensie / tren rulare: fuzeta, bara stabilizare, arc elicoidal, caseta directie, bascule, brat roata, jug motor,punte spate, telescop, pompa servo directie, port-fuzeta;
Elemente racire: electroventilator ac / clima, radiator intercooler, termoflot, electroventilator habitaclu, electroventilator apa, radiator clima, radiator apa, racitor ulei;
Elemente de siguranta: airbag sofer, airbag pasager, airbag lateral, calculator airbag / centralina, centura de siguranta, pretensionare centura, plansa bord, capac airbag pasager;
Elemente de interior: scaun sofer / pasager, bancheta, cal, cotiera, torpedou, plansa bord, plafon textil, mocheta habitaclu, plafoniera, parasolar, tetiera;
Elemente transmisie: cutie de viteze, placa ambreiaj, disc ambreiaj, volanta, rulment presiune, planetara;
Elemente frana: etrier frana, suport etrier, disc frana, pompa servo frana, tulumba frana, pompa ABS, pompa vacuum;
Elemente electrice: ceas de bord, contact pornire, panou comanda ac / clima, instalatie motor, calculator motor, kit pornire, macara geam, broasca usa, debitmetru aer, motor stergator fata / spate;
