Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Dezmembrari si Piese SH
Old 04-08-13, 13:59   #1
ctdez
Default Dezmembrari Opel Astra G 1.4i, 1.6i, 1.8i, 2.0i, 1.7 DTI, 2.0 DTI - 0765495934
Dezmembrari Auto Opel Astra G
Motorizari disponibile: 1. 4i 16v 66kw (90cp) tip x14xe1. 6i 16v 74kw (100cp) tip x16xel1. 8i 16v 85kw (115cp) tip x18xe12. 0i 16v 100kw (136cp) tip x20xev1. 7 dti (model isuzu) 55kw (75cp) tip y17dt2. 0 dti 60kw (82cp) tip x20dtl2. 0 dti 74kw (100cp)
An fabricatie: 1998 – 2005
Caroserie: hatchback si caravan
Detalii si preturi la 0765495934
aer conditionat , comenzi volan, ABS, trapa electrica, cutie 5 trepte, oglinzi electrice, proiectoare, geamuri electrice, 4 Airbag’uri, computer de bord
Piese Disponibile:
ELEMENTE OPTICE: semnalizator,stop, geam portiera, far, luneta, parbriz, oglinda
ELEMENTE / ANEXEMOTOR: chiuloasa, alternator, compresor clima, baie ulei, pompa ulei, bloc motor, pompa servodirectie, pompa benzina, injector,pompa injectie, biela, electromotor, vibrochen, calculator pompa injectie EDU, piston, ECU, galerie admisie/evacuare, suport motor, turbosuflanta;
ELEMENTE DIRECTIE / SUSPENSIE/TREN RULARE: bara stabilizare, port-fuzeta, jug motor,punte spate, caseta directie, fuzeta, brat roata, arc elicoidal, telescop, pompaservo directie;
ELEMENTE RACIRE MOTOR / HABITACLU: electroventilator habitaclu, radiator apa, teava ac, electroventilator apa, radiator clima,radiator intercooler, termoflot, electroventilator ac / clima;
ELEMENTE SIGURANTA: airbagsofer, capac airbag, airbag lateral, centura siguranta,pretensionare centura, calculator airbag, airbag pasager, plansa bord;
ELEMENTE TRANSMISIE: volanta, rulment presiune, disc ambreaj, utieviteze, planetara, placa ambreaj;
ELEMENTE FRANARE: etrier frana, disc frana, pompa vacuum, pompa servo frana;
ELEMENTE ELECTRICE: ceas de bord,contact pornire, instalatie motor, panou comanda ac / clima, broasca usa, ansamblu stergator parbriz/luneta, calculator motor, macara geam, debitmetru aer;
ctdez is offline   Reply With Quote
