Dezmembrez Audi A6 Avant (4B)(C5) 1.8T, 1.9 TDI, 1.9 TDI PD, 2.5 TDI an fabricatie 1997-2005, 1.8T 110kw (150cp) tip APU, 1.9 TDI 81kw (110cp) tip AFN, 1.9 TDI PD 85kw (115cp) tip AJM, 1.9 TDI PD 96kw (131cp) tip AVF, 2.5 TDI 110kw (150cp) tip AFB si AKN, cutie de viteze AUTOMATA tiptronic si manuala 5+1 si 6+1 trepte, interior piele crem, volan S-Line 3 spite, comenzi volan, scaune full electric, sistem sunet BOSE, trapa electrica, volan piele cu comenzi, cruise control, ABS, ASR, elemente mahon, dublu climatronic, jante tabla si aliaj R15, R16 si R17, cotiera piele, suspensie pneumatica spate, 4X Airbag, geamuri duplex (stratificate), senzori de parcare spate.
Tel: 0723364267
Ym :
constantadezmembrari@yahoo.com
Piese disponibile : ELEMENTE CAROSERIE(aripa fata, capota motor, capota portbagaj, hayon, bara protectie fata-spate, portiere, trager, armatura bara,lonjeron, stalp, prag, aparatoare noroi; ELEMENTE OPTICE(far, semnalizator,stop, geam portiera, luneta, parbriz, oglinda; ELEMENTE/ANEXEMOTOR(turbosuflanta, alternator, electromotor, compresor clima, pompa servodirectie, injector,pompa injectie, pompa inalta presiune, pompa benzina, electrovalva, galerie admisie/evacuare, chiuloasa, bloc motor, vibrochen, piston, biela, baie ulei, pompa ulei, suport motor; ELEMENTEDIRECTIE/SUSPENSIE/TREN RULARE(arc elicoidal, telescop, caseta directie, pompa servo directie electrica , brat roata, bara stabilizare, fuzeta, port-fuzeta, jug motor,punte spate, bascule; ELEMENTE RACIRE MOTOR/HABITACLU(radiator apa, radiator clima,radiator intercooler, termoflot, electroventilator apa,racitor ulei, electroventilator ac / clima, teava ac, electroventilator habitaclu; ELEMENTE SIGURANTA(airbag sofer, airbag pasager, airbag lateral, calculator airbag, centura siguranta,pretensionare centura, plansa bord, capac airbag; pasager, ELEMENTE TRANSMISIE(cutieviteze, placa ambreaj, disc ambreaj, volanta, rulment presiune, planetara;ELEMENTE FRANARE(etrier frana, disc frana, pompa servo frana, pompa vacuum;ELEMENTE ELECTRICE(calculator motor, instalatie motor, ansamblu stergator parbriz/luneta, panou comanda ac / clima, macara geam, broasca usa, ceas de bord,contact pornire, debitmetru aer;
