Go Back   Forum 4Tuning > AUTO COMERCIAL > Bazar AUTO - PIESE, ACCESORII, CONSUMABILE, etc > Dezmembrari si Piese SH
Old 09-11-09, 21:08   #1
ppaarroollaa
Default dezmembrez opel astra g hatchbak an 2000 motor 1,6 benzina
dezmembrez opel astra g benzina HATCHBACK an 2000 1.600 cmc culoare bleo deschis
cutie viteze 800 RON
bloc motor complet 2800 RON
suport motor stanga 90 RON
suport motor dreapta 90 RON
capota 250 RON(neechipata)
suport motor spate 90 RON
geam dreapta fata 130 ron
usa stanga fata (neechipata) 300 ron
4 jante aliaj spitate ozz racing 17"+ cauciucuri 300 e
usa portbagaj completa 400 RON
bobina inductie 200 RON
coloana directie 200 RON
pedalier ambreiaj 50 RON
pedalier frana 50 RON
pompa frana 150 RON
pedalier acceleratie 120 RON
instalatie electrica interior 250 RON
usi spate 420 ron bucata
centura fata dr 80 RON
centura fata st 80 RON
tweetere fata 30 RON
volan + airbag 450 RON
scrumiera 35 RON
arc dr spate 80 RON
arc st spate 80 RON
arc dr fata 80 RON
arc st spate 80 RON
motor spergator parbriz 150 RON
motor stergator luneta 100 RON
brat stergator luneta 50 ron
contact + cheie + yale 200 RON
stopuri clare 300 ron
plastic prag stanga 80 RON
buton avarie 20 RON
display interior 130 RON
consola centrala 100 RON
control aer 130 RON
bloc lumini 80 RON
maneta stergatoare 50 RON
maneta semnalizare 50 RON
bancheta spate 250 RON
4 boxe originale 100 RON
etrier dreapta 100 RON
etrier stanga 100 RON
butuc spate st 100 RON
butuc spate dr 100 RON
vas expansiune 50 RON
bara fata 200 RON
bara spate 210 RON
amortizor st fata 80 RON
amortizor st spate 80 RON
amortizor dr spate 80 RON
punte spate cu tamburi 400 RON
cadru motor 200 RON
radiator 300 RON
scaune fata 280 ron
rezervor 150 RON
alternator 400 RON
electromotor 250 RON
instalatie completa aer conditionat 500 e
faruri+pleoape 300 ron
vas apa stergator 50 RON
motor spalator parbriz 70 RON
plasticul central de sub frana de mana si schimbator 50 RON
oglinda interior 30 RON
set planetare 400 ron
portfuzeta stanga 150 RON
fuzeta drapta 150 RON
usa rezervor+ balama 40 RON
cablu frana de mana 30 RON
servofrana 150 RON
sistem interior frana de mana 50 RON
pompa benzina 100 RON
radiator aeroterma 100 RON
timoniere cutie viteze + schimbator 80 RON
centura siguranta dr spate 50 RON
centura siguranta st spate 50 RON
plastic interior prag st 50 RON
plastic interior prag dr 50 RON
plastic interior stalp 30 RON
mocheta spate 50 RON
mocheta fata 50 RON
filtru aer + cutie 50 RON
capitonaj plafon 100 RON
aripa spate dr 200 RON
aripa spate st 200 RON
stalp st 100 RON
stalp dr 100 RON
prag dr 100 RON
prag st 100 RON
fata usa dr fata 50 RON
fata usa st fata 50 RON
plafon 200 RON
aripa stanga fata 100 RON
evacuare completa remus 400 e
relatii la tel 0721410402 sau id mesenger v_a_n_a_t_o_r_u
ID:	1169397   Click image for larger version
ID:	1169398   Click image for larger version
ID:	1169400   Click image for larger version
ID:	1169401   Click image for larger version
ID:	1169403   Click image for larger version
ID:	1169404   Click image for larger version
ppaarroollaa is offline   Reply With Quote
Old 10-11-09, 21:05   #2
ppaarroollaa
Default Re: dezmembrez opel astra g hatchbak an 2000 motor 1,6 benzina
grila capota sa vandut
Old 12-11-09, 16:23   #3
ppaarroollaa
bloc lumini opel astra g cu comanda proiectoare 100
Old 12-11-09, 16:25   #4
ppaarroollaa
scrumiera fata 25 ron
scrumiera spate 25 ron
Old 13-11-09, 13:00   #5
ppaarroollaa
Default Opel Astra G, 1.6 16v, motor Z16XE benzina, caroserie harchback 5 usi
lista aproape completa de la opel putin modificata
pt cei interesati sunt rugati sa posteze pe forum pt a afla si alti useri detalii si sfaturi despre piese in cazul in care nu li se potrivesc lor multumesc
Old 13-11-09, 13:01   #6
ppaarroollaa
- Actuatoare (inchidere centralizata portbagaj si portiere) 80 ron/buc.
- aeratoare plansa bord si consola centrala – 30 ron/buc.
- arcuri fata-80 ron/buc
- arcuri spate-80 ron/buc.
- aripa fata stanga – 80 ron/buc.
- aripi spate – 200 ron ron/buc.
- amortizoare haion 50 ron/buc.
- alternator – 380 ron negociabil sau 300 ron fara releu incarcare
- airbag volan cu butoane claxon – 50 euro
- airbag pasager 400 ron
- ansamblu antena - 50 ron
- axe cu came – 380 ron/buc.
- arbore cotit – 400 ron
- Baie ulei - 150 ron
- bara fata torsiune 50 ron
- balamale capota fata – 50 ron/buc.
- bara spate – 200 ron
- bara fata 200 ron
- bloc lumini cu buton lumina ceata -80 ron
- bancheta spate fara cu cotiera - 250 ron
- boxe 4 buc 100 ron
- brate suspensie fata – 100 ron/buc.
- brat stergator fata/spate – 30 ron/buc.
- buton avarii - 30 ron
- butuc spate 100 ron bucata
- bloc motor (Z16XE) neg
- boxe portiere Faital – 20 ron/buc.
- bobina inductie- 250 ron (aproape noua)
- bobina electromotor (solenoid) – 80 ron (ca noua)
- buson vas expansiune 15 ron
- Carcasa distributie – 100 ron
- carcasa filtru aer – 100 ron
- cablu frana de mana-50 ron
- cadru sustinere motor-300 ron
- calculator motor 260 euro
- calculator ABS – 200 euro
- calculator airbag-uri si centuri – 300 ron
- capota 250 ron neechipata
- capac motor plastic sigla opel 50 ron
- capac culbutori – 100 ron
- capitonaj plafon-100 ron
- capitonaj capota fata – 100 ron
- capitonaje portiere – 100 ron toate
- capitonaje plastic stalpi – 30 ron/buc. (gri deschis)
- capitonaje plastic prag pe interior – 50 ron/buc. (gri deschis)
- capitonaje mocheta portbagaj – 20 ron/buc.
- carenaje roti fata – 20 lei/buc., spate – 15 ron buc.
- centuri siguranta fata-70 ron buc
- pretensionare centuri-80 E/ bucata
- chiuloasa – 150 euro
- clapeta acceleratie completa – 300 ron
- control aer 130 ron
- contact (partea el. si mecanica) si cheie – 70 ron
- contact +cheie +yale 200 ron
- conducta lunga AC – 180 ron
- consola centrala 80 ron
- consola dintre scaune – 80 ron
- coloana directie reglabila 150 ron
- cutiuta consola central - 25 ron
- cutie viteze stare perfecta( versiunea cu ambreiaj hidraulic) 800 ron
- Disc ambreiaj – 100 ron
- display consola centrala (afisaj ceas, radio cd) – 100 ron
- Electromotor -300 ron negociabil, sau fara solenoid (bobina) – 250 ron
- etrieri fata – 200 ron /buc.
- evacuare completa 350 e remus cu tatuaj pe finala 2 iesiri
- faruri + pleoape 300 ron
- fete usi fata 50 ron buc
- Furtun radiator, cel mic – 20 ron, cel mare 40 ron, alte furtune – 10 ron/buc.
- filtru aer +cutie 50 ron
- frana de mana sistem interior 50 ron
- fuzete – 30 lei/buc.
- flapsuri fata bara 50 ron ambele
- Geamuri laterale – 110 ron/buc.
- geam spate triunghi - 50 ron/buc.
- galerie admisie – 350 ron
- Hayon cu luneta- 300 ron + 200 ron luneta ( se vand si separat)
- Instalatia electrica (toata de interior) 200 ron
- instalatie aer conditionat completa 460 e
- instalatie el. motor – 150 ron
- injectoare – 100 ron/buc
- jante oz racing 17 inch + cauciucuri 200 euro
- Kit geamuri electrice fata 400 ron
- Lonjeron dreapta – 200 lei
- lampa iluminat numar 30 ron
- Macarale manuale geamuri spate – 50 ron/buc.
- modul aprindere electronica (bobina inductie) – 90 euro
- maneta frana mana-80 ron
- maneta stergatoare cu comanda stergator luneta – 70 ron
- maneta semnalizari – 70 ron
- maneta schimbator viteze - 90 ron
- motorase stergatoare fata/spate – 70 ron/buc.
- motor fara accesorii (Z16XE euro 4 cu distributie noua si acte, 150.000 km. reali) – 400 euro
- mochete fata/spate – 50 ron/buc.
- Oglinda interioara -40 ron
- oglinda stanga manuala 110 ron
- Panou frontal – 100 ron
- pedala ambreiaj - 40 ron
- pedala frana - 60 ron
- pedala acceleratie electronic- 120 ron
- pistoane cu biele - 100 ron/buc.
- plafon 200 ron
- planetare – 300 ron stanga, 300 ron dreapta
- pompa bernzina 100 ron
- pompa frana -170ron
- portiere – 300 ron bucata
- pompa servofrana – 300 ron
- pompa ulei - 300 ron
- polita portbagaj haion 100 ron
- pompa apa - 80 ron
- poportfuseta st /dr 150 ron
- plastic interior stalp 30 ron buc
- plasticuri prag stanga / dreapta 70 ron bucata
- plafoniera 45 ron
- plafon tabla-150 ron
- plastic central de sub frana de mana si schimbator 50 ron
- placa presiune – 100 ron
- pompa benzina-170 ron
- puntea spate(echipata) cu tamburi-400 ron
- praguri metalice – 100 ron/buc. (absolut fara rugina)
- pretensionere centuri fata - 150 ron
- radiator aeroterma 100 ron
- Ramforsare bara fata Opel Astra G 50 ron
- rezervor 150 ron
- rampa injectoare – 200 ron
- rezervor 150 ron
- rulment presiune hidraulic – 380 ron
- releu incarcare acumulator de pe alternator – 80 ron
- Scut lateral motor dreapta – 40 ron
- servofrana -150 ron
- stergatoare fata cu motoras -150 ron
- scaune fata (fara airbag) -250 ron
- scrumiera fata - 30 lei, spate – 20 ron
- socluri becuri far-20 lei /buc
- stalpi fata – 150 ron/buc.
- stalpi mijloc – 150 ron/buc.
- stop spate clare 300 ron 2 buc
- sonda Lambda dupa catalizator – 100 ron
- suport baterie 40 ron
- senzori motor – 100 ron/buc.
- servofrana 150 ron
- suporti motor/cutie viteze – 90 ron/buc.
- torpedou -50 ron
- Tablou comanda A/C -100
- tablou bord – 150 ron
- timonerie cutie viteze – 80 ron
- toba mijloc (cu tot cu coloana de evacuare , racord flexibil )-100 ron
- tamburi spate(completi) - 180lei sau 90 ron/buc.
- twetere fata - 30 ron ambele
- usa stanga fata neechipata 300 ron
- usi spate 420 ron bucata echipata
- usa portbagaj completa 400 ron
- Usita rezervor cu balama -50 ron
- Vas expansiune – 50 ron fara buson
- vas spalator parbriz , alte vase lichide frana etc.– 50 ron/buc.
- volanta – 400 ron
- volan + airbag 400 ron
preturile sunt usor negociabile
Old 17-11-09, 08:39   #7
ppaarroollaa
faruri opel astra g vandute
jante oz racing vandute
Old 24-11-09, 09:03   #8
ppaarroollaa
Default x16xel este tipul motorului
dezmembrez opel astra g tipul motorului este x16xel
Old 24-11-09, 17:39   #9
domi
caseta de directie este?
si cu cit.merci
domi is offline   Reply With Quote
Old 24-11-09, 17:40   #10
pieseauto.iasi
un pret la radiatorul ac
pieseauto.iasi is offline   Reply With Quote
Old 25-11-09, 11:57   #11
ppaarroollaa
salutare baieti
pretul la caseta de directie este in jur de 700 ron
iar pretul la radiator este de 150 ron
Old 17-12-09, 17:07   #12
ppaarroollaa
bloc de lumini cu buton de proiectoare sa vandut
Old 17-12-09, 17:08   #13
ppaarroollaa
jantele oz vandute
Old 17-12-09, 17:52   #14
aanggello
Originally Posted by ppaarroollaa View Post
jantele oz vandute
ma intereseaza mufa de lampa de pe aripa, cea care vine pe instalatie+bandou usa spate stang
un pret te rog
aanggello is offline   Reply With Quote
Old 24-12-09, 04:59   #15
simpaticu
simpaticu's Avatar
COMPRESOR AC ?
simpaticu is offline   Reply With Quote
- Copyright 2025 4Tuning -
