Dintre acestea:
Ground Zero GZIA 2125HPX(siguranta 25a )
* Amplificator 2 canale
* Putere RMS:
o 2 x 80W (4 ohmi)
o 2 x 125W (2 ohmi)
o 1 x 300W (4 ohmi, punte)
* Sursa MOSFET
* Lowpass regrabil: 30 - 250 Hz
* Highpass reglabil: 40 - 3000 Hz
* Intrare "high level"
* Intrare RCA
BLAUPUNKT EMA 460 (1 siguranta 40a)
o Amplificator auto Blaupunkt EMA 460
o 4/3/2 canale
o Number of channels 4/3/2 ch Class A/B
o max. power@4 ohms 4x110 / 2x350 watts
o RMS power@4 ohms 4x55 / 2x160 watts
o RMS power@2 ohms 4x80 watts
o Frequency response 10 - 25000 Hz
o Signal/noise ratio > 90 dBA
Magnat xCite 560W ( 1 siguranta 40a)
System 4-channel amplifier
Max. 4x 140/2x 340 watts
RMS power output into 4 ohms 4x 70/2x 170 watts
Max. power output into 1 ohms 4x 180 watts
RMS power output into 2 ohms 4x 90 watts
Frequency response 5 - 100.000 Hz (-3 dB)
Harmonic distortion <0,05 %
Philips XP640:
are 2 sigurante de 25 a
si cica ar scoate:
4x80wrms @ 4 0hm, 2x220wrms @ 4ohm
care ar fii mai ok dintre cele mentionate mai sus....calitate...mai multi watti...
toate sunt cam la acelasi pret...second hand!
pentru inceput vreau sa folosesc la subowooferul acesta:
http://www.quoka.de/hifi-audio-tv-vi..._44329103.html
PS: precizez ca o sa achizitionez un subwoofer mai puternic in viitor.
