Va rog lamuritima si pe mine pentru a se auzi mai mult pe bass si nu inalte ce ar trebui sa aibe boxele respective?Ohmi,raspuns in frecventa,?
Eu unu vreau niste boxe hertz adica astea:HERTZ DSK 165 KIT 2Way+Grille
Thanks to DIECI SYSTEM, you can easily build very good quality audio systems. Woofers performs at best when used in factory cut-outs and DT 16 neodymium tweeter provides clear, wide high frequency response. The passive filters, directly made on connecting wires, and rich hardware given with these systems increase installation possibilities, in whatever conditions.
Size - 165mm (6.1/2") Woofer. 15mm (19/32") Tweeter.
Comp - 2 Way system: High density flux ferrite magnet, water repellent pressed paper cone woofer + DT16 tweeter.
Xover - Factory provided crossovers - DX100 (Tweeter) + DX200 (low pass)
Sensitivity - 93dB/SPL
Power - 160W Peak Power, 80W xontinuos Program Power
Frequency Range - 50Hz - 21kHz
Impedence - 4 Ohm.
Sunt bune pentru o auditie de muzica hip hop,house ceva mai mult bass
Sau dati-mi voi idei de alte boxe.Cu stima.
