Old 19-03-09, 12:38   #1
Klean
Klean's Avatar
Default MIVOC HQ 25030 - 3 way
Chiar sa fie atat de mare RMS-ul la setul asta
Am cautat pe gugal si cam tot ce gasesc e in Germana, Maghiara...
Stie cineva ceva despre firma macar?
Par sa fie "frati" cu Raveland...conform aici
Cam ce amplificare ar necesita...ca daca ma iau dupa cifrele date de ei...
10 X
Klean is offline   Reply With Quote
Old 20-03-09, 14:30   #2
Klean
Klean's Avatar
Default Re: MIVOC HQ 25030 - 3 way
Am comis-o oricum. Luni vine coletul. Revin cu poze si impresii...
Old 20-03-09, 16:09   #3
Klean
Klean's Avatar
Am comis-o grav.
Woofer-ul are 25 cm
Traducere de la gugal:
The 3-way Composystem of superlatives. This assumes a 250 mm woofer powerful bass. For the customer, not the tube or box in his trunk wishes, this set is a real alternative. Experience voluminous sound that leaves nothing to be desired. Dry, powerful bass, smooth mids and clear highs clean shape the sound components of this system. The 12 dB crossover network is optimally tuned. The midrange (100 mm) is already relatively early use, so the woofer of its function as a bass supplier optimally meet. The pivoting tweeter with variable mounting option completes the trio perfectly harmonious upwards from.
Old 23-03-09, 08:23   #4
Klean
Klean's Avatar
A venit...Monstruos...mai tarziu poze...nu stiu cum o sa pun wooferele care sunt imenseeee...
Old 23-03-09, 09:27   #5
Klean
Klean's Avatar
Asa.
Am facut cateva poze in comparatie cu un batranel Nokia 1000 si ceva...
Intrebarea ramane aceeasi, cat de adevarate sunt cifrele date de producator...
Interesant, mid-range este practic capsulat.
Amplificatorul va veni de la Ploiesti in maxim 3 saptamani, un LRX 6.9, si merg pe amplificarea activa a celor 3 componente (67 watts x 4 + 72 watts x 2 ).
Nu cred ca difuzoarele se vor ridica la nivelul LRX dar daca ne-am lua toti Focal, DLS si Hertz unde ar mai fi fun-ul
Probabil ar trebui mutat acest post deja in Coltul incepatorului sau la unitati de bord, fiiind un pas ulterior achizitionarii amplificatorului.
Name:	tweeter front.jpg
ID:	843717   Click image for larger version
Name:	mid front.jpg
ID:	843718   Click image for larger version
Name:	mid profile.jpg
ID:	843720   Click image for larger version
Name:	Woofer front.jpg
ID:	843721   Click image for larger version
Name:	woofer profile.jpg
ID:	843723   Click image for larger version
Name:	cross front.jpg
ID:	843724   Click image for larger version
Name:	cross top off.jpg
Old 24-03-09, 07:50   #6
Klean
Klean's Avatar
Schimbare de planri majora. Se poate inchide.
Old 30-03-09, 13:32   #7
AlexBanu
AlexBanu's Avatar
Exclamation Re: MIVOC HQ 25030 - 3 way
Ai montat componentele..ti-a venit ampliful..cum sunt?
