MIVOC HQ 25030 - 3 way
Re: MIVOC HQ 25030 - 3 way
Am comis-o oricum. Luni vine coletul. Revin cu poze si impresii...
Am comis-o grav:shock:.
Woofer-ul are 25 cm :omfg::omfg: Traducere de la gugal: The 3-way Composystem of superlatives. This assumes a 250 mm woofer powerful bass. For the customer, not the tube or box in his trunk wishes, this set is a real alternative. Experience voluminous sound that leaves nothing to be desired. Dry, powerful bass, smooth mids and clear highs clean shape the sound components of this system. The 12 dB crossover network is optimally tuned. The midrange (100 mm) is already relatively early use, so the woofer of its function as a bass supplier optimally meet. The pivoting tweeter with variable mounting option completes the trio perfectly harmonious upwards from. |
A venit...Monstruos...mai tarziu poze...nu stiu cum o sa pun wooferele care sunt imenseeee...
9 Attachment(s)
Asa.
Am facut cateva poze in comparatie cu un batranel Nokia 1000 si ceva... Intrebarea ramane aceeasi, cat de adevarate sunt cifrele date de producator... Interesant, mid-range este practic capsulat. Amplificatorul va veni de la Ploiesti in maxim 3 saptamani, un LRX 6.9, si merg pe amplificarea activa a celor 3 componente (67 watts x 4 + 72 watts x 2 ). Nu cred ca difuzoarele se vor ridica la nivelul LRX dar daca ne-am lua toti Focal, DLS si Hertz unde ar mai fi fun-ul:?: Probabil ar trebui mutat acest post deja in Coltul incepatorului sau la unitati de bord, fiiind un pas ulterior achizitionarii amplificatorului. |
Schimbare de planri majora. Se poate inchide.
Ai montat componentele..ti-a venit ampliful..cum sunt?
| All times are GMT +2. The time now is 09:04. |
