Old 15-05-11, 03:22   #1
sgf203
Default KENWOOD KAC-9150D =Clasa D
mi am luat am luat amplificatoru mai jos mentionat....imi trebuie ajutor in achizitionarea unui subwoofer......aveti ceva sfaturi???
->KENWOOD KAC-9150D =Clasa D
Putere maxima:
1800W
Putere RMS:
500W x 1 (4Ω)
900W x 1 (1Ω)
Stabil in 1 ohm
Bass Boost 40Hz (0~+18dB)
In conformitate cu CEA-2006
Filtru Low-pass: 50~200Hz (24dB/oct)
Filtru infrasonic: 15/25Hz (18dB/oct)
Compatibil Dual Mono Drive
Intrare de nivel inalt
Indicator de stare
Iluminare albastra
Ventilator de racire
Functie de protectie
Putere masurata CEA: 500W x 1 in 4 ohmi si 1% THD
Raspuns in frecventa: 5Hz ~ 200Hz
Raport semnal/zgomot : 100dB
Raport semnal/zgomot (CEA-2006): 75dBa (referinta: 1 Watt in 4 Ohmi)
Consum maxim: 57A
Dimensiuni (WxHxD): 350 x 59 x 238(mm)
sgf203 is offline   Reply With Quote
Old 15-05-11, 06:26   #2
sgf203
Default Re: KENWOOD KAC-9105D =Clasa D
IN PRIMA POSTARE>>>AM GRESIT MODELU' AMPLIFICATORULUI
mi am luat am luat amplificatoru mai jos mentionat....imi trebuie ajutor in achizitionarea unui subwoofer......aveti ceva sfaturi???pretu sa fie maxim 1000ron
->KENWOOD KAC-9105D =Clasa D
Putere maxima:
1800W
Putere RMS:
500W x 1 (4Ω)
900W x 1 (1Ω)
Stabil in 1 ohm
Indicator de stare
Iluminare albastra
Consum maxim: 57A
Dimensiuni (WxHxD): 350 x 59 x 238(mm)[/QUOTE]
Old 15-05-11, 09:49   #3
ralphmandl
ralphmandl's Avatar
Default Re: KENWOOD KAC-9150D =Clasa D
SPL Dynamics xtr-300D2
Old 15-05-11, 16:37   #4
sgf203
ms ralphmandl....f.interesant....m am interesat de Spl Dynamics Xtr 300d2.....si l am gasit si la un pret f.bun zic eu(500 ron)dar nu stiu prea multe despre SPL....nu sunt cunoscator
Ce am gasit eu suna cam asa....
---Subwoofer Auto
Diametru 12 inch(30cm)
Putere Maxima 1500 W
Putere Nominala (RMS) 750 W
Impedanta 2 x 2 ohmi
Raspuns Frecventa 20-100 Hz
Sensibilitate 86,6 dB/W/m
Excursie Difuzor Xmax 22mm
Magnet 160 Oz
Vas 41,7 litri
Chrome Backplate
Enhanced Voice Coil Cooling
Sasiu Aluminiu
Adancime Instalare 170 mm
Greutate 11,3 kg
Produsul este Second hand
Pret: 500 LEI
As vrea sa stiu daca incinta este buna pt difuzoru respectiv.
Old 15-05-11, 22:43   #5
ralphmandl
ralphmandl's Avatar
care incinta?
pretul difuzorului este foarte bun.
Old 15-05-11, 22:55   #6
sgf203
nu am inca datele pt incinta....am postat astfel...crezand ca o sa imi raspunda respectivu la mail mai repede....inca astept sa imi trimita datele incintei
pretul ar fi 500 ron cu tot cu incinta...de asta am pus problema incintei ca mi s a parut cam dubios
Old 16-05-11, 11:36   #7
razvy_zeus
razvy_zeus's Avatar
Hai sa-ti propun si eu un difuzor ... ce zici de Alpine SWR-1223D ? --- E un difuzor foarte ok care duce mai mult decat zice in specificatii
razvy_zeus is offline   Reply With Quote
Old 16-05-11, 21:08   #8
ralphmandl
ralphmandl's Avatar
500 de lei cu tot cu lada, hmmm..... mi se pare cam mic pretu sincer. credeam ca-i doar difu. cine vinde difuzorul stie cam ce paote acel dif? poate are o lada cu o gaura(gaura nu port!) si suna ca dracu.
CNCA 2011 @ Expo ARAD International (Stok Open): 143.05db (Record National!)
CNCA 2012 @ Expo ARAD International (Mini 1000): 139.4db
CNCA 2012 @ ERA ORADEA Shopping Center (Maxi 5000): 141.7db
CNCA 2012 @ Galleria Mall ARAD (Maxi 5000): 141.19db
https://forum.4tuning.ro/120-masina-m...2-visiniu.html
Old 16-05-11, 21:20   #9
sgf203
am primit raspuns la mail de la respecivu....mi a zis ca este o incinta de 30 l inchisa....si ca difuzoru are 2 ani vechime dar cica este in perfecta stare de functionare.....1.ce parare aveti despre incinte?(este compatibila cu difuzoru...o sa se auda bine)2.ce parere aveti despre vechimea difuzorului?(mai lucreaza la capacitate maxima)3>pretul de 500 ron este doar pt difuzor,incinta o da bonus dupa spusele lui....intrebarea mea este daca se merita sa il cumpar pe asta.....sau mai bine sa il cumpar nou(pretul ar fi cam 700-750 ron)
despre alpine-u ala....am citit pe forum chiar comparatia intre cele doua difuzoare(xtr300d2 vs alpine SWR- 1223D)...si cam toti tind sa spre xtr ca ar fi mai bun....
Old 16-05-11, 22:08   #10
ralphmandl
ralphmandl's Avatar
se poate sa fie in stare perfecta, dar se poate sa nu fie, mai bine cumperi unul nou si sti o treaba, cat despre "toata lumea tinde spre xtr" eu zic sa nu te iei neaparat dupa ce spune lumea, cu xtr-300D2 ti-am dat un exemplu de dif potent pt tine, ideal ar fi sa le asculti pe amandoua ininte sa cumperi un dif.
Old 17-05-11, 00:01   #11
sgf203
Problema ar fi cu incinta...ca nu stiu cum sa o fac...din ce am citit e dstul de complicat.....si din ce am vazut pe net de vanzare mi se par foarte scumpe....mai scumpe ca difuzoru....de asta ma incanta oferta cu 500 ron ca are si incinta....dar sa inteleg ca este cam degeaba incinta aia
Am mai cautat si eu si propun niste difuzoare:
1-Pioneer TS-W309D4...as pune 2 dif intr-o incinta
2-Kenwood kfc-w3012...as pune 2 dif intr-o incinta
3-Kicker Solo-Baric L7...1 dif
Ce parere aveti?....bine inteles ca intra in discutie si difuzoarele propuse de voi
Old 17-05-11, 11:11   #12
ralphmandl
ralphmandl's Avatar
o incinta paralelipipedica la vre-o 70 de litri, acordata pe la 35hz, ar fi suficient, o sa-ti fac un mic proiect de lada mai incolo, acum nu am timp.
Old 17-05-11, 23:22   #13
sgf203
ms...cred ca o incinta de 60 L este suficienta,din ce am citit si eu despre difuzor...
Bass-Reflex box - Car / Hifi 60 L + 4" port / length 25cm Tuning frequency 35Hz
Bass-Reflex box - Car / Loudmusic 50 L + 4" port / length 22cm Tuning frequency 40Hz
Bass-Reflex box - Home Theatre 65 L + 4" port / length 33cm Tuning frequency 30Hz
Old 18-05-11, 21:48   #14
ralphmandl
ralphmandl's Avatar
varianta la 30hz ar fi cea mai spectaculaosa.
Old 19-05-11, 06:20   #15
sgf203
din ce am vazut...nu ai mare experienta in a construi incinte....si tie ti a facut cineva incinta.....crezi ca esti in masura sa imi calculezi incinta???
