KENWOOD KAC-9150D =Clasa D
mi am luat am luat amplificatoru mai jos mentionat....imi trebuie ajutor in achizitionarea unui subwoofer......aveti ceva sfaturi???
->KENWOOD KAC-9150D =Clasa D Putere maxima: 1800W Putere RMS: 500W x 1 (4Ω) 900W x 1 (1Ω) Stabil in 1 ohm Bass Boost 40Hz (0~+18dB) In conformitate cu CEA-2006 Filtru Low-pass: 50~200Hz (24dB/oct) Filtru infrasonic: 15/25Hz (18dB/oct) Compatibil Dual Mono Drive Intrare de nivel inalt Indicator de stare Iluminare albastra Ventilator de racire Functie de protectie Putere masurata CEA: 500W x 1 in 4 ohmi si 1% THD Raspuns in frecventa: 5Hz ~ 200Hz Raport semnal/zgomot : 100dB Raport semnal/zgomot (CEA-2006): 75dBa (referinta: 1 Watt in 4 Ohmi) Consum maxim: 57A Dimensiuni (WxHxD): 350 x 59 x 238(mm) |
Re: KENWOOD KAC-9105D =Clasa D
IN PRIMA POSTARE>>>AM GRESIT MODELU' AMPLIFICATORULUI
mi am luat am luat amplificatoru mai jos mentionat....imi trebuie ajutor in achizitionarea unui subwoofer......aveti ceva sfaturi???pretu sa fie maxim 1000ron ->KENWOOD KAC-9105D =Clasa D Putere maxima: 1800W Putere RMS: 500W x 1 (4Ω) 900W x 1 (1Ω) Stabil in 1 ohm Bass Boost 40Hz (0~+18dB) In conformitate cu CEA-2006 Filtru Low-pass: 50~200Hz (24dB/oct) Filtru infrasonic: 15/25Hz (18dB/oct) Compatibil Dual Mono Drive Intrare de nivel inalt Indicator de stare Iluminare albastra Ventilator de racire Functie de protectie Putere masurata CEA: 500W x 1 in 4 ohmi si 1% THD Raspuns in frecventa: 5Hz ~ 200Hz Raport semnal/zgomot : 100dB Raport semnal/zgomot (CEA-2006): 75dBa (referinta: 1 Watt in 4 Ohmi) Consum maxim: 57A Dimensiuni (WxHxD): 350 x 59 x 238(mm)[/QUOTE] |
Re: KENWOOD KAC-9150D =Clasa D
SPL Dynamics xtr-300D2
ms ralphmandl....f.interesant....m am interesat de Spl Dynamics Xtr 300d2.....si l am gasit si la un pret f.bun zic eu(500 ron)dar nu stiu prea multe despre SPL....nu sunt cunoscator
Ce am gasit eu suna cam asa.... ---Subwoofer Auto Diametru 12 inch(30cm) Putere Maxima 1500 W Putere Nominala (RMS) 750 W Impedanta 2 x 2 ohmi Raspuns Frecventa 20-100 Hz Sensibilitate 86,6 dB/W/m Excursie Difuzor Xmax 22mm Magnet 160 Oz Vas 41,7 litri Chrome Backplate Enhanced Voice Coil Cooling Sasiu Aluminiu Adancime Instalare 170 mm Greutate 11,3 kg Produsul este Second hand Pret: 500 LEI As vrea sa stiu daca incinta este buna pt difuzoru respectiv. |
care incinta?
pretul difuzorului este foarte bun. |
nu am inca datele pt incinta....am postat astfel...crezand ca o sa imi raspunda respectivu la mail mai repede....inca astept sa imi trimita datele incintei
pretul ar fi 500 ron cu tot cu incinta...de asta am pus problema incintei ca mi s a parut cam dubios |
Hai sa-ti propun si eu un difuzor ... ce zici de Alpine SWR-1223D ? --- E un difuzor foarte ok care duce mai mult decat zice in specificatii ;)
500 de lei cu tot cu lada, hmmm..... mi se pare cam mic pretu sincer. credeam ca-i doar difu. cine vinde difuzorul stie cam ce paote acel dif? poate are o lada cu o gaura(gaura nu port!) si suna ca dracu.
am primit raspuns la mail de la respecivu....mi a zis ca este o incinta de 30 l inchisa....si ca difuzoru are 2 ani vechime dar cica este in perfecta stare de functionare.....1.ce parare aveti despre incinte?(este compatibila cu difuzoru...o sa se auda bine)2.ce parere aveti despre vechimea difuzorului?(mai lucreaza la capacitate maxima)3>pretul de 500 ron este doar pt difuzor,incinta o da bonus dupa spusele lui....intrebarea mea este daca se merita sa il cumpar pe asta.....sau mai bine sa il cumpar nou(pretul ar fi cam 700-750 ron)
despre alpine-u ala....am citit pe forum chiar comparatia intre cele doua difuzoare(xtr300d2 vs alpine SWR- 1223D)...si cam toti tind sa spre xtr ca ar fi mai bun.... |
se poate sa fie in stare perfecta, dar se poate sa nu fie, mai bine cumperi unul nou si sti o treaba, cat despre "toata lumea tinde spre xtr" eu zic sa nu te iei neaparat dupa ce spune lumea, cu xtr-300D2 ti-am dat un exemplu de dif potent pt tine, ideal ar fi sa le asculti pe amandoua ininte sa cumperi un dif.
Problema ar fi cu incinta...ca nu stiu cum sa o fac...din ce am citit e dstul de complicat.....si din ce am vazut pe net de vanzare mi se par foarte scumpe....mai scumpe ca difuzoru:o....de asta ma incanta oferta cu 500 ron ca are si incinta....dar sa inteleg ca este cam degeaba incinta aia
Am mai cautat si eu si propun niste difuzoare: 1-Pioneer TS-W309D4...as pune 2 dif intr-o incinta 2-Kenwood kfc-w3012...as pune 2 dif intr-o incinta 3-Kicker Solo-Baric L7...1 dif Ce parere aveti?....bine inteles ca intra in discutie si difuzoarele propuse de voi |
o incinta paralelipipedica la vre-o 70 de litri, acordata pe la 35hz, ar fi suficient, o sa-ti fac un mic proiect de lada mai incolo, acum nu am timp.
ms...cred ca o incinta de 60 L este suficienta,din ce am citit si eu despre difuzor...
Bass-Reflex box - Car / Hifi 60 L + 4" port / length 25cm Tuning frequency 35Hz Bass-Reflex box - Car / Loudmusic 50 L + 4" port / length 22cm Tuning frequency 40Hz Bass-Reflex box - Home Theatre 65 L + 4" port / length 33cm Tuning frequency 30Hz |
varianta la 30hz ar fi cea mai spectaculaosa.
din ce am vazut...nu ai mare experienta in a construi incinte....si tie ti a facut cineva incinta.....crezi ca esti in masura sa imi calculezi incinta???:-)
| All times are GMT +2. The time now is 07:09. |
