Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 20-05-10, 11:21   #1
MH-79-TUN
MH-79-TUN's Avatar
Default Megane 2
Una bucata Megane si multe incercari pana sa ajung la acest rezultat.
Componente:
-medii Ground Zero Competition 16.5
-Kickbass Ground Zero Hidrogen 16.5
-Inalte Ground Zero Hidrogen
-Sub MTX 9515 cu 2 bobine de 4 ohmi
-Amplificator VIBE LiteBox Stereo 4 chanel folosit in punte scotand 250w pe canal
-Si amplificator Ground Zero Nuclear pt sub folosit acuma pe 2 ohmi si 1500w
-Filtre Vibe Space 3D pe 3 cai care pe mine ma multumesc si n-o sa umblu la ele doar dupa ce uit cat de greu am ajuns aici si prind curaj sa fac alta configuratie
-CD Alpine CDA 9855r
-2 trasee de 20 si de 50 mm
-condensator Ground Zero 1F
-Rigidizare cu STP care a fost atat de evident ca si-a facut treaba incat un ma asteptam si clar am fost placut surprins sa vad diferenta enorma...
Pe fata capitonajele de usi au fost remodelate cu fibra de sticla,rasina,praf de marmura si marmura,totul prind 4 inele MDF lucrate la freza CNC si intarite cu alte inele de MDF de 18 mm.
ID:	1479684   Click image for larger version
ID:	1479685   Click image for larger version
ID:	1479687   Click image for larger version
ID:	1479688   Click image for larger version
ID:	1479690   Click image for larger version
ID:	1479691   Click image for larger version
ID:	1479693   Click image for larger version
ID:	1479694   Click image for larger version
ID:	1479696   Click image for larger version
ID:	1479697   Click image for larger version
ID:	1479699   Click image for larger version
ID:	1479700   Click image for larger version
ID:	1479702   Click image for larger version
ID:	1479703   Click image for larger version
ID:	1479705   Click image for larger version
ID:	1479727   Click image for larger version
ID:	1479729   Click image for larger version
MH-79-TUN is offline   Reply With Quote
Old 22-09-10, 16:30   #2
MH-79-TUN
MH-79-TUN's Avatar
Default Re: Megane 2
Upgrade la parte de SUB.
Vineri pleaca spre Romania un Nuclear de 15 si 2500 watt plus doua membrane pasive de la Plutonium tot de 15 intr-o incinta care s-a mai facut (multi cunosc un Fiat Bravo),cu mica diferenta a sub-ului ....
Incinta va fi 50% MDF si cealalta jumatate laminata in fibra,cam aceeasi compozitie pe care am folosit-o si la usi,adica adaugat praf de marmura pt o mai buna rigidizare,mochetata..nu mai are rost sa o vopsesc pt ca imi iau prea mult finisarile si pregatirile pt vopsea,asa ca o solutie super viabila este mocheta neagra ca tine la "tavaleala".
Old 22-09-10, 16:35   #3
ovidiu89
ovidiu89's Avatar
bafta cu proiectul. se pare ca severinul sta foarte bine la categoria sound
ovidiu89 is offline   Reply With Quote
Old 22-09-10, 22:29   #4
furry_lion
furry_lion's Avatar
Cool Re: Megane 2
succes in continuare si asteptam sa ne mai delectezi si pe noi cu noutatii !!
furry_lion is offline   Reply With Quote
Old 23-09-10, 09:05   #5
MH-79-TUN
MH-79-TUN's Avatar
Di fericire pentru noi cei din zona asta,avem un om de calibru greu (IM) care ne ajuta pe multe planuri ,dazvoltand aceasta pasiune.Sau , cum mai zicea cineva: dealer-ul local ne atrage cu multe reduceri.
Ce e aiurea,este timpul care cateodata se dovedeste a lipsi din diferite motive dar,pasiunea sau hobby-ul asta ca si altele,merita ceva sacrificii de orice fel ar fi ele si ar trebui sa nu uitam asta,atunci cand ne adresam unul altuia.
In faza de proiect a schimbat multe...aveam in cap ceva si acum e cu totul alceva,dar preconizez ca va iesi cum trebuie
Multumesc pt urari!
Old 23-09-10, 11:30   #6
teddyb
Ford Driver
teddyb's Avatar
hai hai hai florine cu ceva low!!!!
teddyb is offline   Reply With Quote
Old 24-09-10, 09:37   #7
MH-79-TUN
MH-79-TUN's Avatar
Promit ca o sa fie ,ca prea multe sacrifici facem pt.asta.
Old 12-10-10, 17:39   #8
NeAgA
NeAgA's Avatar
Frumos lucrat
NeAgA is offline   Reply With Quote
Old 13-10-10, 00:39   #9
TM18SID
frumos facut....deja regret tot mai tare ca nu am pus si eu 2 difuri pe usa
TM18SID is offline   Reply With Quote
Old 13-10-10, 09:14   #10
MH-79-TUN
MH-79-TUN's Avatar
Daca asta iti doresti de ce sa nu o faci?
Old 13-10-10, 14:22   #11
MH-79-TUN
MH-79-TUN's Avatar
Sal!
Trebuie sa ma explic:
Cele doua traductoare sunt diferite chiar foarte mult..ele lucreaza individual unul de celalalt dar din lipsa de timp si din graba,nu am mai pozat si momentul in care kick-ul a fost lasat sa "zburde" in voie si tot nu chiar asa cum am vrut,gaura din spatele lui nefiind cat trebuie,dar este dajuns...cat despre medii ele sunt inchise,neavand legatura cu kick-ul.
Fata de plastic este foare bine prinsa,inclusiv in suruburi care nu se vad in poze,plus clemele ei care spre surprinderea mea sunt extrem de robuste,indurand maltratari destul de mari la cat am vrut eu sa fie de fixe pe tabla usii.
Din nefericire la Timisoara am fost doar ca spectator,masina fiind nici pe departe terminata,dar sperante sunt si cu sigurantava veni si finalizarea.
Old 13-10-10, 17:53   #12
TM18SID
tocmai ce am terminat fetele de usi in prop de 99% si sa ma apuc iara de la 0 nu mai am nervi...e ok si asa dar era mai spectaculos cu 2
Old 14-10-10, 08:26   #13
MH-79-TUN
MH-79-TUN's Avatar
Cunosc sentimentul...mie mi-a luat aproape un an sa prind curaj ca sa continui ce am in cap...dar sper ca asta sa fie finalul..
Spor la munca!!
Old 16-10-10, 19:25   #14
NeAgA
NeAgA's Avatar
Arrow Re: Megane 2
Nistee filmulete cevaa:>
Old 16-10-10, 19:48   #15
alex_bmw1992
alex_bmw1992's Avatar
pozele nuti mai plac ? ....
alex_bmw1992 is offline   Reply With Quote
