Pai imi insir si eu ce am pe masina...astept pareri/sugestii pro/contra...ms :P
HeadUnit :
Jvc kd-sh9101
Type CD, MP3
Power yes
Display Type Monochrome
Media CD-R, CD-RW
Tuner yes, digital
Frequency range 5-20000 Hz
Format CD-audio, MP3, WMA
Office changer CD
CD-player yes
MP3-player yes
DVD-player No
Equalizer yes
TV Tuner No
IR remote yes
Joystick on the wheel No
Pause when talking on the phone yes
DSSA a
Auto Stations yes
Movable panel a
Support bands FM, MW, LW
Dynamic Range 106 dB
Support RDS RDS, RDS / EON
The number of preset FM / AM 18
nominal and peak power 4x19 Vt/4x50 Tue
Platform 1 din
Interface CD-changer custom
Color silver
Dimming lights yes
Number of line inputs 1
Number of line outputs 3
Outputs a subwoofer
Support Bluetooth No
Connecting to the standard ISO a
Gold-plated connectors yes
Tone Control yes
Number of bits DAC 24
Signal - Noise 106 dB
Number of equalizer bands 7
Number of preset equalizer 12
Support Tag ID3 a
CD-Text yes
ratio. Distortion 0.0015%
Features Turn off the amplifier. Accurate 20-bit signal processing compressed MP3 and WMA. Memory for sound settings.
Boxe Fata
Hifonics Zeus ZXi 5.2C Compo System
2-way 13 cm component speaker system.
Power (max/RMS): 200/100 Watt
Diameter: 13 cm
Frequency response: 61Hz-25kHz
Tweeter: Neodymium magnet dome, 12 mm diameter
2 boxe alpine SPG-17C2
difuzoare coaxiale cu 2 cai
dimensiuni woofer: 16,5 cm
tweeter cu magnet din neodynium
putere RMS: 60W
putere Max: 240W
impedanta: 4 ohmi
raspuns in frecventa: 68Hz - 20KHz
sensibilitate: 88,5dB (W/m)
Boxele de pe fata sunt legate la player se aud binisor pana fac rost de un amplificator :S
Boxe spate
Hifonics Zeus Zxi 693
* difuzoare coaxiale cu 3 cai
* dimensiuni: 15 x 23cm (6x9")
* putere Max: 550W
* putere RMS: 110W
* raspuns in frecventa: 43Hz - 24KHz
* nivel reglabil tweeter: 0 / -3 / +3dB
* tweetere cu magnet de Neodymium
* logo iluminat
* sistem de ventilatie al bobinei
Difuzoare Pionner TS-A6813i
difuzoare coaxiale ovale 6 x 8"
putere RMS: 40 W
putere maxima: 350 W
impedanta: 4 Ohmi
raspuns in frecventa: 30-30000 Hz
diametru woofer: 14.5 x 20.4 cm
diametru tweeter: 11 mm
diametru midrange: 13 mm
adancime de montaj: 61 mm
Sony XS-W1620 6.5" Car Tweeter
Momentan boxele de pe spate sunt puse pe un amplificator pe doua canale nu stiu firma nici puterea :S siguranta 35 amperi :S
Subwoofer
Hifonics Zeus Zx1214
Incinta bandpass cu 2 diffuri Zeus Hifonics 12" 2x450 WRMS 2X900 watt
Amplificator
Ground Zero Hydrogen Gzha 2350x
amplificator 2 canale
MOSFET
putere RMS:
2 x 200W (4 ohmi)
2 x 350W (2 ohmi)
2 x 450W (1 ohm)
1 x 632W (4 ohmi, punte)
1 x 1000 (2 ohmi, punte)
stabil la 1 ohm
raspuns in frecventa: 10Hz - 40KHz
distorsiuni: 0.01%
raport semnal / zgomot: 98dB
filtru LPF variabil: 30 - 250Hz
filtru HPF variabil: 40 - 3000Hz
bass boost variabil: 0 - +12dB (30 - 50Hz)
filtru subsonic variabil: 10Hz - 40Hz
reglaj faza variabil: 0 - 180
sensibilitate intrare: 100mV - 6V
Condesator Hifonics HFC1000 1 farad
Bateria este una comerciala de 75 de amperi :S
Revin cu poze :S
