Sa o luam de la capat
Statia Alpine MRP-M650
Specificatii:
PUTERE
Per canal ,4 ohmi: 400W x 1 (0.08% THD)
Per canal ,2 ohmi: 600W x 1
In punte, 4 ohmi: 1000W x 1 W
RASPUNS IN FRECVENTA
20Hz - 200Hz (+3/-3dB)
ALTELE
Filtru Subsonic
Egalizor bass
Crossover selectabil (LP)
Crossover reglabil (LP)
Alimentare MOSFET
Alimentare DC-DC PWM
Conectori de intrare RCA placati cu aur
BassEngine®
Frecventa crossover : 50Hz-200Hz,-24dB-oct (LP)
Filtru subsonic (Fix): 15Hz
Frecventa egalizorului de bass (Fixa): 50Hz 0 la +12dB
Raport semnal/zgomot (S/N): 90dBA
Sensibilitate la intrare : 0.2V la 4.0V
Impedanta la intrare: 10k Ohmi
Impedanta iesire: 4 sau 2 ohmi
Cablurile sunt de 20 mm de la Alfatec.
Sistemul cum am mai zis pe fata inca este stoc.
Pe spate am asa:
Sistem difuzoare Crunch GTS 6.5c
Specificatii:
Sistem de difuzoare de 16.5cm pe doua cai
* Putere maxima 300W
* Putere nominala 60W RMS
* Raspuns in frecventa 59Hz - 21kHz
* Sensibilitate 91 dB
* Impedanta 4 Ohm
* Membrana din alfaceluloza laminata cu argint.
HU: Sony Xplod CDX-R3350
Putere 4 x 52 wati, Redare CD/CD-R/CD-RW/MP3/Atrac 3, Tuner digital, FM/AM/LW, RDS, Telecomanda inclusa, Motion Blade, Drive-S, S-MOSFET, Iesire pentru preamplificator sau Subwoofer spate.
In viitorul destul de apropiat (cel putin sper sa fie apropiat
) as vrea sa imi schimb playerul cu acesta :
Clarion dzx788usb
Specificatii:
* CD-R/RW ready
* MP3, WMA and iTunes® AAC compatible with ID3-TAG display
* Rear USB connector with maximum track capacity: 130,560 (255 tracks in 512 folders)
* WMDRM 10 playback via supported MTP device
* 18 FM, 6 MW/LW station presets
* RDS-EON DSP tuner with variable bandwidth and Radio Text display
* iPod® direct control via USB
* 6-volt / 6-channel audio pre-out
* Subwoofer level control
* 24-bit D/A converter
* Sound Restorer
* Digital Z-Enhancer sound customisation
* Digital time alignment control
* 3-way active crossover
* 3-band parametric equaliser
* Built-in High Pass Filter & Low Pass Filter
* Built-in amplifier canceller
* 4-channel × 53 watts of MOS-FET amplification
* Motorised sloping console
* 728-variable colour display and illuminated keys
* Full dot display with Screensavers
* "SLIDETRAK" for dynamic operation
* Mobile input and Phone mute
* Auxilliary input with level control
* CeNET control of Bluetooth® interface adapter BLT583 ready for handsfree and 6-disc CD changer
* OEM steering wheel remote wired interface capability
* Detachable control panel
