Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 22-09-08, 17:23   #1
Razvan_Golf2
Razvan_Golf2's Avatar
Default VW Golf 2 KICKER&MAGNAT
Sal sa imi prezint si eu sistemul meu ,sper ca am ales ce trebuie
Razvan_Golf2 is offline   Reply With Quote
Old 22-09-08, 17:26   #2
Razvan_Golf2
Default Re: VW Golf 2 KICKER&MAGNAT
Radio CD Player cu MP3 si WMA
tuner RDS, 30 de posturi presetate (FM:18/MW:6/LW:6)
compatibil CD Text, CD Text Scroll, ID3 tag
reglaj avansat bass / treble (BassEngine®)
amplificator 4 x 50W (Micro Dynamics™)
control CD Changer
panou frontal rabatabil negru cu butoane cu iluminare variabila (albastru / verde / portocaliu / rosu)
buton volum rotativ si retractabil
functie Quick Search
3 x PreOut (2V)
control nivel iesire subwoofer
Versatile Link™ AUX-IN
Old 22-09-08, 17:28   #3
Razvan_Golf2
DVD player 1xDIN cu touchscreen
Display LCD complet motorizat cu unghi reglabil
Compatibil DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, CD-DA, MP3, WMA, VCD, MPEG1, MPEG2, MPEG4, AVI, JPEG, DivX
Procesor sunet pe 24biti - 192kHz DAC
Amplificator incorporat 4x40W
Iesire de subwoofer
Compatibil 5.1 Dolby Digital
Tuner Radio compatibil RDS cu 30 de memorii
Intrare Video Auxiliara
Compatibil Ipod (necesita cablul optional Jlink), interfata grafica Ipod
Rezolutie 336960 pixeli
Old 22-09-08, 17:34   #4
Razvan_Golf2
8 difuzoare MAGNAT
sistem de difuzoare pe 2 cai
diametru woofer: 16.5 cm, diametru tweeter: 25mm
putere: 200W RMS (400W max)
SPL: 90 dB
raspuns in frecventa: 26 - 35.000 Hz
impedanta: 4 ohmi
Old 22-09-08, 17:44   #5
Razvan_Golf2
La cele 8 difuzoare adaug 2 amplificator auto 4 canale
putere
4 ohmi, stereo: 4 x 125W RMS (4 x 250W max)
2 ohmi, stereo: 4 x 160W RMS (4 x 320W max)
4 ohmi in punte: 2 x 325W RMS (2 x 650W max)
Raspuns in frecventa 5 Hz - 50 Khz
THD < 0,05 % (1 kHz)
filtre LPF si HPF variabile 40-300 Hz, 12 dB
filtru subsonic 15 Hz, 12 dB
Bass boost variabil 0-15 dB la 45 Hz
dimensiuni 350 x 350 x 261 mm
intrari / iesiri RCA aurite
Old 22-09-08, 17:55   #6
Razvan_Golf2
Ca difuzor de bas am optat pt un KICKER SOLO X de 18" eu zic ca am facut o treaba buna
ID:	649784   Click image for larger version
Old 22-09-08, 18:02   #7
Razvan_Golf2
Si ca putere pt difuzor am ales Hifonics Colossus XI
← home
Classic:
2 x 600W @ 4 ohms
2 x 900W @ 2 ohms
2 x 1200W @ 1 ohm
1 x 1800W @ 4 ohms
1 x 2400W @ 2 ohms
Fuse: External 160A Final Edition:
2 x 600W @ 4 ohms
2 x 1000W @ 2 ohms
2 x 1500W @ 1 ohm
1 x 2000W @ 4 ohms
1 x 3000W @ 2 ohms
Fuse: External 300A
Dimensions: 33.4" x 10.4" x 2.45" (848mm x 265mm x 62mm)
ID:	649789   Click image for larger version
Old 22-09-08, 18:06   #8
Razvan_Golf2
Am mai ales si un RODEK Hybrid Carbon-Capacitor 40F Blue LED, 500Watt
¦ 40 Farad Hybrid Carbon Capacitor
¦ 21 V surge voltage
¦ brushed aluminium housing
¦ chromed terminals
¦ additional internal lighting with 10 blue high-brightness LEDs
¦ massive direct connector blocks 35/50 mm2 Power-In, 20/10 mm2 power-out for three amps
¦ display-uri albastre separate pentru voltaj si amperaj
Old 22-09-08, 18:10   #9
Razvan_Golf2
si inca 2condensatore 1 Farad pt cele ce amplificatoare pt difuzoare
21 VDC
voltmetru digital cu LCD
activare remote
Old 22-09-08, 18:12   #10
Razvan_Golf2
Si in plus mai sunt cablurile si alte chesti eu zic ca am facut o alegere buna ,voi reveni cu poze cand ma voi apuca sa le montez pe masina
Old 22-09-08, 21:09   #11
ReLLaXX
ReLLaXX's Avatar
[Registered Users]
Ai nevoie de curent (baterii) si incinta BUNA pentru difuzorul ala. Ai ales lucruri utile si lucruri mai putin utile. Dar per total, cu putina atentie, poti sa faci un sistem interesant.
Bafta multa si inca o data, atentie la curent si la incinta subwooferului!
www.melodix.ro
Old 22-09-08, 22:20   #12
Razvan_Golf2
iti multumesc frumos pt sfat sa sti ca mam gandit si eu la partea cu,curentul .Si dac mar indruma cineva spre cineva care poate sa imi fac o incinta reusita asi fi recunoscator ms
Old 23-09-08, 11:38   #13
sharkky
sharkky's Avatar
Poze reale cu aceste componente nu ai?
Foarte subnutrit S18X cu Hifonicsu ala ...
sharkky is offline   Reply With Quote
Old 23-09-08, 20:05   #14
Razvan_Golf2
Multumit ????? am adaugat poze ne reale pt ca sunt facute mai bine si sunt mai clare
ID:	651005   Click image for larger version
Old 23-09-08, 20:33   #15
Bigu
Bigu's Avatar
incinta care apare in poze este definitiva??? sper ca nu
