VW Golf 2 KICKER&MAGNAT
Sal sa imi prezint si eu sistemul meu ,sper ca am ales ce trebuie :D
Re: VW Golf 2 KICKER&MAGNAT
Radio CD Player cu MP3 si WMA
tuner RDS, 30 de posturi presetate (FM:18/MW:6/LW:6) compatibil CD Text, CD Text Scroll, ID3 tag reglaj avansat bass / treble (BassEngine®) amplificator 4 x 50W (Micro Dynamics™) control CD Changer panou frontal rabatabil negru cu butoane cu iluminare variabila (albastru / verde / portocaliu / rosu) buton volum rotativ si retractabil functie Quick Search 3 x PreOut (2V) control nivel iesire subwoofer Versatile Link™ AUX-IN |
DVD player 1xDIN cu touchscreen
Display LCD complet motorizat cu unghi reglabil Compatibil DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, CD-DA, MP3, WMA, VCD, MPEG1, MPEG2, MPEG4, AVI, JPEG, DivX Procesor sunet pe 24biti - 192kHz DAC Amplificator incorporat 4x40W Iesire de subwoofer Compatibil 5.1 Dolby Digital Tuner Radio compatibil RDS cu 30 de memorii Intrare Video Auxiliara Compatibil Ipod (necesita cablul optional Jlink), interfata grafica Ipod Rezolutie 336960 pixeli |
8 difuzoare MAGNAT
sistem de difuzoare pe 2 cai diametru woofer: 16.5 cm, diametru tweeter: 25mm putere: 200W RMS (400W max) SPL: 90 dB raspuns in frecventa: 26 - 35.000 Hz impedanta: 4 ohmi |
La cele 8 difuzoare adaug 2 amplificator auto 4 canale
putere 4 ohmi, stereo: 4 x 125W RMS (4 x 250W max) 2 ohmi, stereo: 4 x 160W RMS (4 x 320W max) 4 ohmi in punte: 2 x 325W RMS (2 x 650W max) Raspuns in frecventa 5 Hz - 50 Khz THD < 0,05 % (1 kHz) filtre LPF si HPF variabile 40-300 Hz, 12 dB filtru subsonic 15 Hz, 12 dB Bass boost variabil 0-15 dB la 45 Hz dimensiuni 350 x 350 x 261 mm intrari / iesiri RCA aurite |
Ca difuzor de bas am optat pt un KICKER SOLO X de 18" eu zic ca am facut o treaba buna :D
Si ca putere pt difuzor am ales Hifonics Colossus XI
← home Classic: 2 x 600W @ 4 ohms 2 x 900W @ 2 ohms 2 x 1200W @ 1 ohm 1 x 1800W @ 4 ohms 1 x 2400W @ 2 ohms Fuse: External 160A Final Edition: 2 x 600W @ 4 ohms 2 x 1000W @ 2 ohms 2 x 1500W @ 1 ohm 1 x 2000W @ 4 ohms 1 x 3000W @ 2 ohms Fuse: External 300A Dimensions: 33.4" x 10.4" x 2.45" (848mm x 265mm x 62mm) |
Am mai ales si un RODEK Hybrid Carbon-Capacitor 40F Blue LED, 500Watt
¦ 40 Farad Hybrid Carbon Capacitor ¦ 21 V surge voltage ¦ brushed aluminium housing ¦ chromed terminals ¦ additional internal lighting with 10 blue high-brightness LEDs ¦ massive direct connector blocks 35/50 mm2 Power-In, 20/10 mm2 power-out for three amps ¦ display-uri albastre separate pentru voltaj si amperaj |
si inca 2condensatore 1 Farad pt cele ce amplificatoare pt difuzoare
21 VDC voltmetru digital cu LCD activare remote |
Si in plus mai sunt cablurile si alte chesti eu zic ca am facut o alegere buna ,voi reveni cu poze cand ma voi apuca sa le montez pe masina :D:D:D
Ai nevoie de curent (baterii) si incinta BUNA pentru difuzorul ala. Ai ales lucruri utile si lucruri mai putin utile. :) Dar per total, cu putina atentie, poti sa faci un sistem interesant.
Bafta multa si inca o data, atentie la curent si la incinta subwooferului! |
iti multumesc frumos pt sfat sa sti ca mam gandit si eu la partea cu,curentul .Si dac mar indruma cineva spre cineva care poate sa imi fac o incinta reusita asi fi recunoscator ms :)
Poze reale cu aceste componente nu ai?
Foarte subnutrit S18X cu Hifonicsu ala ... |
Multumit ????? am adaugat poze ne reale pt ca sunt facute mai bine si sunt mai clare:D
incinta care apare in poze este definitiva??? sper ca nu
| All times are GMT +2. The time now is 02:35. |
