Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Arata-ti sunetul! > Sistemul Audio de pe Masina Mea
Sistemul Audio de pe Masina Mea Sistemul Audio de pe Masina Mea
Old 08-04-10, 13:21   #1
IM
IM's Avatar
Thumbs up Citroen C4 Picasso - Democar Genesis / Ground Zero / Scan-Speak / Project88 by IM
Timpul zboara!!!
Dupa 2 ani, a venit momentul de intra in profunde transformari audiomobilul care a reprezentat Romania la Supercupa Europeana EMMA@Work - 2008, reusind sa surclaseze celelalte echipe participante... amintiri de neuitat....
Voi incerca sa prezint, pas cu pas, noul proiect care este in curs de desfasurare.
Componentele ce urmeaza a fi folosite sunt urmatoarele:
- Alpine F1 Status plus procesor
- Amplificator custom Genesis, un singur corp, compus din Dual Mono Clasa A / Dual Mono Clasa A / Dual Mono / Stereo 100
- Traductoare Ground Zero Reference / Scan-Speak / Project88
- Conectica Aurix
Vor fi setate doua sisteme:
- SQ 6 canale (2tw ...plus... 2medii/joase ...plus... sw in fata ...plus... sw in spate)
- Multimedia DTS/Dolby Digital 5.1
Pure Music
"The myth is stronger than the truth,
And the truth can sometimes lie
To see all from what it was
You need an uncorrupted eye..."
ionutmocioiu-on-facebook.com
IM is offline   Reply With Quote
Old 08-04-10, 13:31   #2
animalutz
animalutz's Avatar
[Street Gambler]
Default Re: Citroen C4 Picasso - Democar Genesis / Ground Zero / Scan-Speak / Project88 by IM
Se renunta la difuzoarele de medii?
animalutz is offline   Reply With Quote
Old 08-04-10, 15:01   #3
IM
IM's Avatar
Da.
Se vor folosi:
- 2 tweetere... probabil Ground Zero Reference 25 sau Ring Radiator-ul de la Scan-Speak
- 2 medii/joase Scan-Speak Revelator 13cm.
- subwoofer fata: Scan-Speak Revelator 26W sau 23W
- Subwoofer spate: Project 88 Power 12 impreuna cu 2 membrane pasive Scan-Speak 23W
...plus... pentru 5.1
- 1 pereche de componente / inca ne stabilit brandul, ce este clar este ca vor fi de 10cm
- 1 traductor identic cu cele care vor fi folosite pentru surround spate, instalat central in bord
Old 08-04-10, 15:09   #4
IM
IM's Avatar
Cu inima cat un purice - subsemnatul, a inceput macelul... Florin, "macelaru cu caciula neagra" a dat dovada de mult zel...
Momente de maxima intensitate au urmat... parca imi treceau prin fata ochilor toate etapele construirii acestei console...
ID:	1408847   Click image for larger version
ID:	1408848   Click image for larger version
ID:	1408850   Click image for larger version
Old 08-04-10, 15:11   #5
IM
IM's Avatar
...deci nu pot sa spun ca seara nu am plecat cu subbassul in portbagaj!
Old 08-04-10, 15:14   #6
IM
IM's Avatar
A urmat producerea, dintr-o bucata veche de mahon, a elementelor care ulterior se va vor transforma intr-o noua consola pentru amplificatorul Genesis
ID:	1408853   Click image for larger version
ID:	1408854   Click image for larger version
ID:	1408856   Click image for larger version
ID:	1408857   Click image for larger version
Old 08-04-10, 15:16   #7
IM
IM's Avatar
Amplificatorul devine curios la vederea mahonului...
ID:	1408859   Click image for larger version
ID:	1408860   Click image for larger version
Old 08-04-10, 15:19   #8
IM
IM's Avatar
Kill-arirea sepcii de la bord cu toate ca parea floare la ureche, ne-a creat ceva probleme in a obtine o obturare a vizibilitatii de maxim 2 degete in ceeace ce priveste displayul Alpine, conform cu Regulamentul EMMA.
ID:	1408863   Click image for larger version
ID:	1408864   Click image for larger version
ID:	1408866   Click image for larger version
ID:	1408867   Click image for larger version
ID:	1408869   Click image for larger version
Old 08-04-10, 15:22   #9
IM
IM's Avatar
In imaginile 24 - 26, se observa ceva de sticla... sa fie oare vasele de racire a lichidului care va tine amplificatorul in limitele optime de temperatura???!
ID:	1408890   Click image for larger version
ID:	1408891   Click image for larger version
Old 08-04-10, 15:31   #10
IM
IM's Avatar
"Imoralul" de mine uite asa a devenit si olar.
Si astfel, olarul incepu sa isi stoarca creerii in a lamina "borcanele".
De laminat tot laminez de vreo 8 ani incoace, dar ...in borcan, este pentru prima data!
Rabdare, rabdare, rabdare....
Strat dupa strat, cu frica la inceput, am inceput in a aplica strat dupa strat: rasina / rasina cu praf si rumegus de mahon / again and again.... un strat de tesatura de fibra de sticla, urmat de rasina si praf de marmura si un ultim strat de impletitura de fibra de sticla. Ultima data se va aplica un strat de SilentCoat la interior!
ID:	1408897   Click image for larger version
ID:	1408898   Click image for larger version
ID:	1408900   Click image for larger version
ID:	1408901   Click image for larger version
ID:	1408903   Click image for larger version
Old 08-04-10, 15:44   #11
IM
IM's Avatar
la cuptor...
ID:	1408935   Click image for larger version
ID:	1408936   Click image for larger version
Name:	la cuptor.jpg
Old 08-04-10, 15:50   #12
IM
IM's Avatar
sapca este inca in faza de... slefuire...
ID:	1408949   Click image for larger version
ID:	1408950   Click image for larger version
Old 08-04-10, 17:35   #13
cristi_timidu
cristi_timidu's Avatar
mai poate comenta cineva ceva?
tot respectu
cristi_timidu is offline   Reply With Quote
Old 08-04-10, 21:36   #14
margineanu ovidiu
margineanu ovidiu's Avatar
Originally Posted by IM View Post
Da.
Se vor folosi:
in primul rand spor la lucru,maret proiect,eu abia astept sa ascult cum suna un 26W,am cochetat mult cu ideea unei incinte sealed cu doua bucati dar frica ca nu voi fi deplin satisfacut din cauza nevoii mele acute de bas am renuntat sa bag atatia bani desi sunt convins ca suna extraordinar de bine.....cat despre 23W erau idealul meu de kick in usi,dar cum bugetul decide multe am ramas la seria clasic care e bun dar ar mai incape
TEAM SQNLL
DIY Mobile Audio
7ch active,audison&soundstream&u dimension
scanspeak D2904/7100,15M ,21W/8554-00,jl12w7,d511r,h701,400bt,2xhollywood spv20,2xspv45
margineanu ovidiu is offline   Reply With Quote
Old 08-04-10, 22:09   #15
teddyb
Ford Driver
teddyb's Avatar
foarte frumos proiect!!!abia astept sa o pot asculta si multa bafta in continuare!!!
ps: se prevede o partecipare la europene?!?:>
teddyb is offline   Reply With Quote
- Copyright 2025 4Tuning -
