Old 06-09-08, 02:06   #1
CataNOS
CataNOS's Avatar
Default Cum conectez Helix SPXL 12 cu Helix SPXL 1000?
Salut,
Am woofer Helix SPXL 12 si amplif Helix SPXL 1000.
Urmeaza sa le montez si habar n-am cum se face conexiunea pentru 1 ohm intre woofer si statie.
Statia are iesire +--+ si nu imi dau seama cum se leaga bridged...
Multumesc
CataNOS is offline   Reply With Quote
Old 06-09-08, 08:41   #2
Bigu
Bigu's Avatar
Default Re: Cum conectez Helix SPXL 12 cu Helix SPXL 1000?
de obicei + de la un canal si - de la altul, asta in cazul in care stie statia bridge
Old 06-09-08, 17:41   #3
CataNOS
CataNOS's Avatar
am primit un raspuns de la Audiotec-Fischer, dar e ambiguu:
"Hello,
The SPXL Amplifier is a MONO Amplifier. The 2 + connectors are intern connect together. And also the 2 - connectors. So you must connect each + connector of the voice coil with a + connector of the Amplifier. And each - connector of the voice coil with a - connector of the Amplifier."
Deci pana la urma statia trece singura in 1 ohm? Mie mi se pare ca impedanta va fi de 4 ohmi in configuratia de mai sus..
Old 06-09-08, 19:37   #4
CataNOS
CataNOS's Avatar
se poate inchide, m-am lamurit. Multumesc Rellaxx!
