Cum conectez Helix SPXL 12 cu Helix SPXL 1000?
Salut,
Am woofer Helix SPXL 12 si amplif Helix SPXL 1000. Urmeaza sa le montez si habar n-am cum se face conexiunea pentru 1 ohm intre woofer si statie. Statia are iesire +--+ si nu imi dau seama cum se leaga bridged... Multumesc |
Re: Cum conectez Helix SPXL 12 cu Helix SPXL 1000?
de obicei + de la un canal si - de la altul, asta in cazul in care stie statia bridge
am primit un raspuns de la Audiotec-Fischer, dar e ambiguu:
"Hello, The SPXL Amplifier is a MONO Amplifier. The 2 + connectors are intern connect together. And also the 2 - connectors. So you must connect each + connector of the voice coil with a + connector of the Amplifier. And each - connector of the voice coil with a - connector of the Amplifier." Deci pana la urma statia trece singura in 1 ohm? Mie mi se pare ca impedanta va fi de 4 ohmi in configuratia de mai sus.. |
se poate inchide, m-am lamurit. Multumesc Rellaxx!
| All times are GMT +2. The time now is 16:09. |
