Old 05-04-07, 05:39   #1
Veve
Veve's Avatar
[Toyota]
Question Cateva explicatii daca se poate.
In multe manuale tehnice, in special la subwoofere se dau niste parametri.
Vreau si eu sa stiu ce inseamna fiecare in parte.
Mai precis: D (mm), Xmas (mm), Le (mH@1kHz), Le (mH@10kHz), Vas (lit), Mms (gr), Cms (mm/N), BL (T-m), Qts, Qes, Qms. Restul (Spl, Re, Fs) le stiu.
Multumesc.
Veve is offline   Reply With Quote
Old 11-04-07, 15:20   #2
Veve
Veve's Avatar
[Toyota]
Default Re: Cateva explicatii daca se poate.
anyone?...
Old 11-04-07, 17:30   #3
vpower16v
Prior to 1970, there were no easy or affordable methods accepted as standard in the industry for obtaining comparative data about loudspeaker performance. Recognized laboratory tests were expensive and unrealistic for the thousands of individuals needing performance information. Standard measurement criteria were required to enable manufacturers to publish consistent data for customers to make comparisons between various loudspeakers.
Thiele-Small Parameters
In the early seventies, several technical papers were presented to the AES (Audio Engineering Society) that resulted in the development of what we know today as 'Thiele-Small Parameters'. These papers were authored by A.N.Thiele and Richard H. Small. Thiele was the senior engineer of design and development for the Australian Broadcasting Commission and was responsible at the time for the Federal Engineering Laboratory, as well as for analyzing the design of equipment and systems for sound and vision broadcasting. Small was, at the time, a Commonwealth Post-graduate Research Student in the School of Electrical Engineering at the University of Sydney.
Theile-Small Params:
Fs
Re
Le
Qms
Qes
Qts
Vas
Cms
Vd
BL
Mms
Rms
EBP
Xmax/Xmech
Sd
Zmax
Usable Freq. Range
Power Handling
Sensitivity
Thiele and Small devoted considerable effort to show how the following parameters define the relationship between a speaker and a particular enclosure. However, they can be invaluable in making choices because they tell you far more about the transducer's real performance than the basic benchmarks of size, maximum power rating or average sensitivity.
Fs This parameter is the free-air resonant frequency of a speaker. Simply stated, it is the point at which the weight of the moving parts of the speaker becomes balanced with the force of the speaker suspension when in motion. If you've ever seen a piece of string start humming uncontrollably in the wind, you have seen the effect of reaching a resonant frequency. It is important to know this information so that you can prevent your enclosure from 'ringing'. With a loudspeaker, the mass of the moving parts, and the stiffness of the suspension (surround and spider) are the key elements that affect the resonant frequency. As a general rule of thumb, a lower Fs indicates a woofer that would be better for low-frequency reproduction than a woofer with a higher Fs. This is not always the case though, because other parameters affect the ultimate performance as well.
Re This is the DC resistance of the driver measured with an ohm meter and it is often referred to as the 'DCR'. This measurement will almost always be less than the driver's nominal impedance. Consumers sometimes get concerned the Re is less than the published impedance and fear that amplifiers will be overloaded. Due to the fact that the inductance of a speaker rises with a rise in frequency, it is unlikely that the amplifier will often see the DC resistance as its load.
Le This is the voice coil inductance measured in millihenries (mH). The industry standard is to measure inductance at 1,000 Hz. As frequencies get higher there will be a rise in impedance above Re. This is because the voice coil is acting as an inductor. Consequently, the impedance of a speaker is not a fixed resistance, but can be represented as a curve that changes as the input frequency changes. Maximum impedance (Zmax) occurs at Fs.
Q Parameters Qms, Qes, and Qts are measurements related to the control of a transducer's suspension when it reaches the resonant frequency (Fs). The suspension must prevent any lateral motion that might allow the voice coil and pole to touch (this would destroy the loudspeaker). The suspension must also act like a shock absorber. Qms is a measurement of the control coming from the speaker's mechanical suspension system (the surround and spider). View these components like springs. Qes is a measurement of the control coming from the speaker's electrical suspension system (the voice coil and magnet). Opposing forces from the mechanical and electrical suspensions act to absorb shock. Qts is called the 'Total Q' of the driver and is derived from an equation where Qes is multiplied by Qms and the result is divided by the sum of the same.
As a general guideline, Qts of 0.4 or below indicates a transducer well suited to a vented enclosure. Qts between 0.4 and 0.7 indicates suitability for a sealed enclosure. Qts of 0.7 or above indicates suitability for free-air or infinite baffle applications. However, there are exceptions! The Eminence Kilomax 18 has a Qts of 0.56. This suggests a sealed enclosure, but in reality it works extremely well in a ported enclosure. Please consider all the parameters when selecting loudspeakers. If you are in any doubt, contact your Eminence representative for technical assistance.
Vas/Cms Vas represents the volume of air that when compressed to one cubic meter exerts the same force as the compliance (Cms) of the suspension in a particular speaker. Vas is one of the trickiest parameters to measure because air pressure changes relative to humidity and temperature — a precisely controlled lab environment is essential. Cms is measured in meters per Newton. Cms is the force exerted by the mechanical suspension of the speaker. It is simply a measurement of its stiffness. Considering stiffness (Cms), in conjunction with the Q parameters gives rise to the kind of subjective decisions made by car manufacturers when tuning cars between comfort to carry the president and precision to go racing. Think of the peaks and valleys of audio signals like a road surface then consider that the ideal speaker suspension is like car suspension that can traverse the rockiest terrain with race-car precision and sensitivity at the speed of a fighter plane. It’s quite a challenge because focusing on any one discipline tends to have a detrimental effect on the others.
Vd This parameter is the Peak Diaphragm Displacement Volume — in other words the volume of air the cone will move. It is calculated by multipying Xmax (Voice Coil Overhang of the driver) by Sd (Surface area of the cone). Vd is noted in cc. The highest Vd figure is desirable for a sub-bass transducer.
BL Expressed in Tesla meters, this is a measurement of the motor strength of a speaker. Think of this as how good a weightlifter the transducer is. A measured mass is applied to the cone forcing it back while the current required for the motor to force the mass back is measured. The formula is mass in grams divided by the current in amperes. A high BL figure indicates a very strong transducer that moves the cone with authority!
Mms This parameter is the combination of the weight of the cone assembly plus the ‘driver radiation mass load’. The weight of the cone assembly is easy: it’s just the sum of the weight of the cone assembly components. The driver radiation mass load is the confusing part. In simple terminology, it is the weight of the air (the amount calculated in Vd) that the cone will have to push.
Rms This parameter represents the mechanical resistance of a driver’s suspension losses. It is a measurement of the absorption qualities of the speaker suspension and is stated in N*sec/m.
EBP This measurement is calculated by dividing Fs by Qes. The EBP figure is used in many enclosure design formulas to determine if a speaker is more suitable for a closed or vented design. An EBP close to 100 usually indicates a speaker that is best suited for a vented enclosure. On the contrary, an EBP closer to 50 usually indicates a speaker best suited for a closed box design. This is merely a starting point. Many well-designed systems have violated this rule of thumb! Qts should also be considered.
gen muzical cautat : manele
Old 11-04-07, 17:31   #4
vpower16v
Xmax/Xmech Short for Maximum Linear Excursion. Speaker output becomes non-linear when the voice coil begins to leave the magnetic gap. Although suspensions can create non-linearity in output, the point at which the number of turns in the gap (see BL) begins to decrease is when distortion starts to increase. Eminence has historically been very conservative with this measurement and indicated only the voice coil overhang (Xmax: Voice coil height minus top plate thickness, divided by 2). Xmech is expressed by Eminence as the lowest of four potential failure condition measurements times 2: Spider crashing on top plate; Voice coil bottoming on back plate; Voice coil coming out of gap above core; Physical limitation of cone. Take the lowest of these measurements then multiply it by two. This gives a distance that describes the maximum mechanical movement of the cone.
Sd This is the actual surface area of the cone, normally given in square cm.
Zmax This parameter represents the speaker’s impedance at resonance.
Usable frequency range This is the frequency range for which Eminence feels the transducer will prove useful. Manufacturers use different techniques for determining ‘Usable Frequency Range’. Most methods are recognized as acceptable in the industry, but can arrive at different results. Technically, many loudspeakers are used to produce frequencies in ranges where they would theoretically be of little use. As frequencies increase, the off-axis coverage of a transducer decreases relative to its diameter. At a certain point, the coverage becomes ‘beamy’ or narrow like the beam of a flashlight. Following is a chart that demonstrates at what frequency this phenomenon occurs relative to the size of the transducer. If you’ve ever stood in front of a guitar amplifier or speaker cabinet, then moved slightly to one side or the other and noticed a different sound, you have experienced this phenomenon and are now aware of why it occurs. Clearly, most two-way enclosures ignore the theory and still perform quite well. The same is true for many guitar amplifiers, but it is useful to know at what point you can expect a compromise in coverage.
Speaker Diameter (inches)
Theoretical Maximum Frequency Before Beaming (Hz)
Power handling This specification is very important to transducer selection. Obviously, you need to choose a loudspeaker that is capable of handling the input power you are going to provide. By the same token, you can destroy a loudspeaker by using too little power. The ideal situation is to choose a loudspeaker that has the capability of handling more power than you can provide lending some headroom and insurance against thermal failure. To use an automobile as an analogy; you would not buy a car that could only go 55mph if that were the speed you always intended to drive. Generally speaking, the number one contributor to a transducer’s power rating is its ability to release thermal energy. This is affected by several design choices, but most notably voice coil size, magnet size, venting, and the adhesives used in voice coil construction. Larger coil and magnet sizes provide more area for heat to dissipate, while venting allows thermal energy to escape and cooler air to enter the motor structure. Equally important is the ability of the voice coil to handle thermal energy. Eminence is renowned for its use of proprietary adhesives and components that maximize the voice coil’s ability to handle extreme temperatures. Mechanical factors must also be considered when determining power handling. A transducer might be able to handle 1,000W from a thermal perspective, but would fail long before that level was reached from a mechanical issue such as the coil hitting the back plate, the coil coming out of the gap, the cone buckling from too much outward movement, or the spider bottoming on the top plate. The most common cause of such a failure would be asking the speaker to produce more low frequencies than it could mechanically produce at the rated power. Be sure to consider the suggested usable frequency range and the Xmech parameter in conjunction with the power rating to avoid such failures. The Eminence power rating is derived using an EIA 426A noise source and test standard. All tests are conducted for eight hours in a free-air, non-temperature controlled environment. Eminence tests samples from each of three different production runs and each sample must pass a test exceeding the rated power by 50 to 100W. The Eminence peak power rating is double that of our standard RMS rating.
Sensitivity This data represents one of the most useful specifications published for any transducer. It is a representation of the efficiency and volume you can expect from a device relative to the input power. Loudspeaker manufacturers follow different rules when obtaining this information — there is not an exact standard accepted by the industry. As a result, it is often the case that loudspeaker buyers are unable to compare apples to apples when looking at the sensitivities of different manufacturers’ products. Please take a look at the Sensitivity Guide for a full analysis of Eminence transducer sensitivities and measurement policies.
chiar daca este in engleza citeste l si incearca sa intelegi ce scrie o sa te ajute ..articol in romana nu cred ca exista daca mai ai nelamuriri incearca cu gugal
Old 11-04-07, 17:47   #5
Veve
Veve's Avatar
[Toyota]
Bun asa ... mersi vpower16v
In romana presupun k nu exista.. sau mai pe scurt (in romana) mi-e mai greu cu datele tehnice in engleza .
Old 13-04-07, 14:29   #6
Extrem
In romania e urmatorul moto :
,, Cumpar un dif cu magnet mare il bag intr-o boxa belea si crap tot ''
Groaznic...
Extrem is offline   Reply With Quote
Old 13-04-07, 14:46   #7
Extrem
Cum se face ?
1. te uiti la parametrii difuzorului, din care reies o gramada de lucruri si eventual faci o simulare a difuzorului in diferite marimi si feluri de incinte.
2. intrebi daca ai posibilitatea pana la ce temperatura rezista adezivul folosit pe bobina (respectiv marimea acestuia) de unde poti deduce la ce puteri rezista difuzorul.
3. asculti difuzorul
4. In functie de simularile facute de tine si eventual de recomandarile producatorului construiesti incinta dintr-un material cat mai rigid (palul fiind un inceput, el fiind varianta low cost, mdf = varianta celui care vrea mai mult decat altii si pentru cine se respecta foloseste lemn de esenta tare cum ar fi stejarul, ulmul, etc).
5. Vezi unde vei folosi boxa, in fuctie de locul unde va fi folosit poti deduce daca vei avea de exemplu 130 decibeli sau 136 reprezantand de 2 ori dublarea puterii, cea ce reprezinta un pas peste asteptarile tale.
Daca ma mai gandesc va mai pot da cateva lucruri ce trebuiesc respectate dar, as fi foarte fericit daca macar 3 din cele enumerate mai sus ar respecta un adevarat pasionat de SQ respectiv SP.
Later...
Old 13-04-07, 16:52   #8
Veve
Veve's Avatar
[Toyota]
Mersi de sfaturi. Unele nu le stiam deci omu` cat traieste invata
Old 13-04-07, 17:32   #9
ReLLaXX
ReLLaXX's Avatar
[Registered Users]
In ceva nr de revista 4tuning.ro ai o lista in limba romana cu cativa parametrii esentiali. Scuze lipsa de exactitate. Cred ca nr 3.
Old 13-04-07, 17:38   #10
Veve
Veve's Avatar
[Toyota]
A bun... dar unde mai gasesc nr 3? ...
