Old 25-07-11, 00:37   #1
Roby_m
Roby_m's Avatar
Default Alpine 3540
Salut
Am intrat in posesia unui amplif Alpine 3540 si am o nelamurire.
http://www.elektroda.pl/rtvforum/fil...zynia_6547.jpg
Pot sa-l folosesc pt amplificarea difuzoarelor spate, adica sa primeasca semnal direct din HU (Alpine 111rm) de la iesirea pt difuzoare?
LE:
Am gasit pe net. Accepta doar low level RCA input.
Roby_m is offline   Reply With Quote
Old 26-07-11, 12:31   #2
ralphmandl
ralphmandl's Avatar
Default Re: Alpine 3540
iti trebuie un adaptor high-low.
Old 26-07-11, 12:42   #3
Roby_m
Roby_m's Avatar
Merci, nici nu stiam ca exista asa ceva.
Old 18-12-12, 18:10   #4
Roby_m
Roby_m's Avatar
Revin asupra intrebarii initiale.
Am gasit pe net datele ei tehnice:
"Power output
2-channel Stereo Mode-----------------------------------65W x 2 (Max)
30W x 2 (into 4Ohms with 0.04% THD)
from 20Hz to 20kHz
Single Channel Bridged Mode -------- 95W x 1(into 4 Ohms with 10% THD)
Signal to Noise Ratio----------------------105dB(referenced to rated power)
Input Sensitivity
(for rated power output)
Fixed -----------------------------500mV
Variable --------------------------100mV-2V
Input Impedance---------------10kOhms
Speaker Impedance----------- 4 or 2ohms(stereo), 4 ohms(bridged)
Power Requirement------------11-16V DC Negative Ground
La ce se refera acele intrari de semnal Fixed si Variable?
Variable nu ar fi cea pt care as putea sa-i dau semnal de nivel inalt, direct din HU?
