Alpine 3540
Salut
Am intrat in posesia unui amplif Alpine 3540 si am o nelamurire. http://www.elektroda.pl/rtvforum/fil...zynia_6547.jpg Pot sa-l folosesc pt amplificarea difuzoarelor spate, adica sa primeasca semnal direct din HU (Alpine 111rm) de la iesirea pt difuzoare? LE: Am gasit pe net. Accepta doar low level RCA input. |
Re: Alpine 3540
iti trebuie un adaptor high-low.
Re: Alpine 3540
Merci, nici nu stiam ca exista asa ceva. :-)
Re: Alpine 3540
Revin asupra intrebarii initiale.
Am gasit pe net datele ei tehnice: "Power output 2-channel Stereo Mode-----------------------------------65W x 2 (Max) 30W x 2 (into 4Ohms with 0.04% THD) from 20Hz to 20kHz Single Channel Bridged Mode -------- 95W x 1(into 4 Ohms with 10% THD) Signal to Noise Ratio----------------------105dB(referenced to rated power) Input Sensitivity (for rated power output) Fixed -----------------------------500mV Variable --------------------------100mV-2V Input Impedance---------------10kOhms Speaker Impedance----------- 4 or 2ohms(stereo), 4 ohms(bridged) Power Requirement------------11-16V DC Negative Ground" La ce se refera acele intrari de semnal Fixed si Variable? Variable nu ar fi cea pt care as putea sa-i dau semnal de nivel inalt, direct din HU? |
| All times are GMT +2. The time now is 23:28. |
