A-si avea nevoie de dimensiunile..o schita eventual pentru o incinta ptr acest subwoofer. v-a fii pus-o intr-un golf 3. Si eventual ce materiale a-si avea nevoie!Ideea este ca nu ma pricep absolut deloc la asa ceva.dar daca a-si avea exact toate dimensiunile m ar ajuta mult!.Multumesc
Model GZRW 30SPL
Voice Coil Diameter mm / inch : 63 / 2,5"
Impedance Ohm : 2 x 2
FS Hz : 33
Qms : 5.97
Qes : 0.38
Qts : 0.36
Vas Litre / cu.ft :. 52 / 1.82
Xmax mm / inch : 20 / 0.8"
BL TESLA – M 18
Power W/ RMS 1000W RMS SPL Power
Mounting hole - mm / inch: 281 / 12.47"
Mounting depth - mm / inch: 150 / 6.45"
Recommended enclosure
Bassreflex / vented
Litre / cu.ft.
42 / 1.47
Port cm / inch
1 x Ø 10 / 4"
18 cm / 7"
