Ajutor Incinta GZRW 30SPL...........
A-si avea nevoie de dimensiunile..o schita eventual pentru o incinta ptr acest subwoofer. v-a fii pus-o intr-un golf 3. Si eventual ce materiale a-si avea nevoie!Ideea este ca nu ma pricep absolut deloc la asa ceva.dar daca a-si avea exact toate dimensiunile m ar ajuta mult!.Multumesc
Model GZRW 30SPL Voice Coil Diameter mm / inch : 63 / 2,5" Impedance Ohm : 2 x 2 FS Hz : 33 Qms : 5.97 Qes : 0.38 Qts : 0.36 Vas Litre / cu.ft :. 52 / 1.82 Xmax mm / inch : 20 / 0.8" BL TESLA – M 18 Power W/ RMS 1000W RMS SPL Power Mounting hole - mm / inch: 281 / 12.47" Mounting depth - mm / inch: 150 / 6.45" Recommended enclosure Bassreflex / vented Litre / cu.ft. 42 / 1.47 Port cm / inch 1 x Ø 10 / 4" 18 cm / 7" |
| All times are GMT +2. The time now is 17:01. |
