Go Back   Forum 4Tuning > Car-Audio, Multimedia & GPS > Car Audio
Car Audio Car Audio
Old 24-02-11, 18:49   #1
magheralex
Default Care-i cea mai buna alegere din cele 5 bass-audio kit ?
1. Statie JBL GTO 752 + Subwoofer JBL CS1204T: **********/catalo...204t.html#galerie - pret 450
subwoofer bass reflex, diametru 30 cm
putere: 250 W RMS (1000W max)
SPL (2,83V/1 m): 90 dB
raspuns in frecventa: 35 - 200 Hz
impedanta: 4 Ohm
dimensiuni: 346 x 660 mm
2. Statie + Subwoofer MAC AUDIO , power bass pack : ***********/produse/Subwoofere_auto/mac_Audio/Power_Box_Bass_Pack/ - pret 549
Subwoofer Mac Audio MPX Box 112
subwoofer de 30cm in incinta bass-reflex
putere nominala - 250W RMS
putere maxima - 800W
raspuns in frecventa - 24-500Hz
sensibilitate - 90dB
impedanta - 4ohmi
dimensiuni: 385 x 365 x 295/355 mm
Amplificator Mac Audio MPX 2500
amplificator auto 2 canale
putere:
4 ohmi, stereo: 2 x 80W RMS
2 ohmi, stereo: 2 x 120W RMS
4 ohmi, in punte: 1 x 240W RMS
raspuns in frecventa: 5 - 50000 Hz (-3 dB)
THD < 0,05% (1 kHz)
SNR > 100 dB
filtre LP si HP variabile 40-300 Hz
bass boost variabil 0-12 dB
dimensiuni: 239 x 59 x 226 mm
3. Amplificator Mac Audio Mpx 2000 + subwoofer Mac Audio MPX Tube 112 - ***********/produ...er_Box_Bass_Pack/ - pret 599
Subwoofer auto Mac Audio MPX Tube 112
putere nominala - 240W RMS
putere maxima - 480W
raspuns in frecventa - 22-200Hz
sensibilitate - 91dB
impedanta - 4ohmi
dimensiuni: 340 x 460 mm
Amplificator auto Mac Audio MPX 2000
putere:
4 ohmi, stereo: 2 x 60W RMS
2 ohmi, stereo: 2 x 80W RMS
4 ohmi, in punte: 1 x 150W RMS
THD < 0,05% (1 kHz)
SNR > 100 dB
4. Statie Magnat Edition Two Limited + subwoofer Magnat subtech 130 - **********/catalo...-two-limited.html - pret 500
5. Magnat B30 bass pack (subwoofer + amplificator) ***********/produ...on_B30_Bass_Pack/ - pret 530
mplificator Magnat Edition Two
amplificator stereo, 2 canale
putere:
4 ohmi, stereo: 2 x 55 W RMS
4 ohmi, in punte: 1 x 150 W RMS
2 ohmi, stereo: 2 x 75 W RMS
stabila la 2 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
bass boost variabil 0 - 12 dB la 45 Hz
filtru low pass variabil 40 - 300 Hz (12 dB)
filtru high pass variabil 40 - 300 Hz (12 dB)
selector mod de functionare 2/1 canale
circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
Subwoofer Magnat Edition B30
subwoofer de tip sealed cu difuzor de 30cm
putere: 250W RMS (800W max)
raspuns in frecventa: 25-250 Hz
SPL: 91 dB
impedanta 4 ohmi
greutate: 11kg
dimensiuni: 430 x 390 x 355/ 265 mm
Ps. am inteles ca Magnat este firma mai ieftina a marcii Mac audio. Asa este?
As vrea unul din cele 5, dar care sa se simta pe masina cu portbagaj separat ... va multumesc antifipat pentru o eventuala parere care m-ar putea ajuta.
Considerati ca un bass reflex e mai bun decat o incinta de tip sealed (fara nicio gaura) sau decat una de tip tub ?!
magheralex is offline   Reply With Quote
Old 24-02-11, 19:00   #2
Stage2
Stage2's Avatar
Default Re: Care-i cea mai buna alegere din cele 5 bass-audio kit ?
Nu cred, eu n-am auzit de asa ceva.
Nici unul.
Depinde ce intelegi prin mai bun. Incinta cu reflex are potentialul sa sune mai tare, da, in acelasi timp are potentialul sa sune mai frumos, da, inseamna ca-i mai bun? nu.
Despre ce masina vorbim ?
,,Motivation get's you going but habit get's you there"
Stage2 is offline   Reply With Quote
Old 24-02-11, 19:04   #3
magheralex
Masina e vectra C / 2003 , berlina
Old 28-02-11, 13:42   #4
razvy_zeus
razvy_zeus's Avatar
Acum depinde si in ce buget vrei sa te incadrezi cu respectivul pachet pentru ca sub 800 ron mai exista variante foarte bune de la Alpine si MTX.
Magnat sa apartina de Mac Audio ..... nici eu nu cred ca e adevarat asa ceva ... unde ai auzit asta ?
razvy_zeus is offline   Reply With Quote
Old 28-02-11, 14:32   #5
AlexBanu
AlexBanu's Avatar
Exclamation Re: Care-i cea mai buna alegere din cele 5 bass-audio kit ?
Da, Magnat si MacAudio apartin aceleiasi companii.
Nu-mi aduc aminte numele companiei dar daca vrei sa te convinzi vezi ca au aceeasi adresa:
http://www.mac-audio.de/index.php?id=3014
http://www.magnat.de/index.php?id=2126&L=0
Magnat Audio-Produkte GmbH
Lise-Meitner-Str. 9
D-50259 Pulheim
Telefon: 02234 / 807-0
Fax: 02234 / 807 - 399
Old 28-02-11, 14:57   #6
Stage2
Stage2's Avatar
Eu unul, tot nu cred sa fie magnat ,,firma mai ieftina a marcii mac audio", ca au aceleasi sediu, nu-mi spune nimic.
Real cu Altex aici au aceleasi sediu, si... ? nu cred sa insemne ca-i mai bun careva.
La fel si Kaufland cu Domo.
Iti multumim Alex de informatie, n-am stiut.
Old 28-02-11, 15:36   #7
magheralex
M-am convins : Mac Audio e firma mama a Magnatului, varianta mai ieftina a lor (lucru cert,confirmat).
Insa intrebarea mea e ce s-ar merita sa-mi iau pe o masina VECTRA C berlina 2003 (are portbagajul separat) , din cele 5 sisteme ? sau mai aveti propuneri de vreun ALPINE ? V-as fi recunoscator ... Vreau sa se auda basul clar, nu sa ... fie cam acelasi lucru ori cu ori fara el in portbagaj.
Old 28-02-11, 17:08   #8
Stage2
Stage2's Avatar
M-am convins : Mac Audio e firma mama a Magnatului, varianta mai ieftina a lor (lucru cert,confirmat) .
Nu se observa deloc la pret, daca-mi impartasesti si mie sursa (poate fi nemeteasca) ar fi perfect.
Ti-am dat un raspuns sincer in primul meu post de aici, tu ai nevoie de ceva capabil sa coboare in frecventa, cele 5 exemple de mai sus nu-s capabile, o parere personala daca vrei sa-ti indeplinesti dorinta ? mai umbla la buget, urca-l.
Old 28-02-11, 21:31   #9
magheralex
Multe firme au sediul in aceeasi locatie, dar niciodata 2 firme nu pot avea acelasi numar de telefon, daca nu sunt practic manageriate de una singura. Mi-a zis un amic care lucreaza la *******, ca Mac Audio e firma mama, ce a ''adoptat'' magnatul (asta nu inseamna ca Magnaturile sunt mai proaste calitativ)
Explica-mi te rog privind frecventa intre cat si cat sa se incadreze pt a se auzi bine in masina mea ? Te referi cumva la raspunsul in frecventa al subwooferului , sa nu urce de la o valoare atat de ridicata precum 25-30 , ci mult mai joaca (gen 5-10 ) ?
Old 01-03-11, 14:39   #10
Stage1
Stage1's Avatar
5-10 hz
Probabil ca vroia sa-ti spuna ca trebuie sa redea cel putin liniar 35-40 hz, ceea ce ma gandesc ca nu se intampla cu variantele propuse de tine.
The power within you...
Old 01-03-11, 18:38   #11
magheralex
Originally Posted by Stage1 View Post
5-10 hz
Imi pare rau dar tot nu m-am lamurit. Pentru a se auzi cat mai bine trebuie ca raspunsul in frecventa sa porneaza de cat mai jos , gen 5Hz ? Nu stiu decat de raspunsul in frecventa al subwooferului , care cu cat porneste de mai jos ... ce se intampla ?
Old 01-03-11, 19:37   #12
Stage1
Stage1's Avatar
Pai tu vrei sa te lamuresti aici din 1-2 fraze? nu esti curios sa citesti putin pentru tine ?
Cum sa-ti explic mai usor, n-are rost sa intru in detaliu, uita de tot ce-i sub 30 hz ca ne complicam fara rost, in primul rand omul sub 20hz nu mai aude, ce rost are sa intram in detalii ca oricum n-ai sa intelegi, google-friend
Intelege ce ti-am scris mai sus, si anume:
Pe inteles, un subwoofer capabil, gasesti fara boxa de la 300 lei in sus, la care se adauga amplif inca vreo 300-400 + boxa, pret variabil in functie de cine ti-o face. Ajungi la 1000 lei, lejer
Pioneer TS-W309S4, GZ GZRW 12S-AL, Alpine SWR-1243D (ai aici 3 exemple, de cam ce ai nevoie).
Old 02-04-12, 21:10   #13
vatmanu
salutare tuturora!! o mare rugaminte am si va rog sa nu ezitati daca stit sa ma ajutati. am un renault laguna 2003 berlina. dispun de 700-900 euro sai cheltui doar pentru muzica. o iau de la zero. deci incepand de la casetofon,boxe,twitere,amplificator,subufer....cam tot. ajutatima sa pun tot cam de aceasi marca si in asa fel sa scoata o claritate superba si un bass cat mai frumos. nu exagerat de tare,,,ma intereseaza claritatea. MUTUMESC pt tot baietzi
vatmanu is offline   Reply With Quote
Old 02-04-12, 23:52   #14
pigoo
pigoo's Avatar
salut, cred ca te pot ajuta cel mai bine de aici.
sunt tot din constanta si ma ocup de tot ce tine de sonorizari auto consiliere/vanzare/montaj.
putem vorbi pe messenger, la telefon.. sau cel mai bine fata in fata.
pigoo is offline   Reply With Quote
Old 03-04-12, 19:56   #15
vatmanu
LASAMI ORICE VREI U. ID, TEL ORICE. TE VOI CONTACTA CU SIGURANTA. ACUM SUNT IN ROMA, DE AIA INTREBAM POATE LUAM CEVA DE AICI CA E MAI IEFTIN ORICUM. APP....AM VAZUT SI CEVA TUNNING PARK. SUNT FOARTE INTERESAT. PE SAMBATA SAU DUMINICA AJUNG LA CONSTANTA. ORICUM, O SA TINEM LEGATURA DACA E.. MS MULT
