1. Statie JBL GTO 752 + Subwoofer JBL CS1204T: **********/catalo...204t.html#galerie - pret 450
subwoofer bass reflex, diametru 30 cm
putere: 250 W RMS (1000W max)
SPL (2,83V/1 m): 90 dB
raspuns in frecventa: 35 - 200 Hz
impedanta: 4 Ohm
dimensiuni: 346 x 660 mm
2. Statie + Subwoofer MAC AUDIO , power bass pack : ***********/produse/Subwoofere_auto/mac_Audio/Power_Box_Bass_Pack/ - pret 549
Subwoofer Mac Audio MPX Box 112
subwoofer de 30cm in incinta bass-reflex
putere nominala - 250W RMS
putere maxima - 800W
raspuns in frecventa - 24-500Hz
sensibilitate - 90dB
impedanta - 4ohmi
dimensiuni: 385 x 365 x 295/355 mm
Amplificator Mac Audio MPX 2500
amplificator auto 2 canale
putere:
4 ohmi, stereo: 2 x 80W RMS
2 ohmi, stereo: 2 x 120W RMS
4 ohmi, in punte: 1 x 240W RMS
raspuns in frecventa: 5 - 50000 Hz (-3 dB)
THD < 0,05% (1 kHz)
SNR > 100 dB
filtre LP si HP variabile 40-300 Hz
bass boost variabil 0-12 dB
dimensiuni: 239 x 59 x 226 mm
3. Amplificator Mac Audio Mpx 2000 + subwoofer Mac Audio MPX Tube 112 - ***********/produ...er_Box_Bass_Pack/ - pret 599
Subwoofer auto Mac Audio MPX Tube 112
putere nominala - 240W RMS
putere maxima - 480W
raspuns in frecventa - 22-200Hz
sensibilitate - 91dB
impedanta - 4ohmi
dimensiuni: 340 x 460 mm
Amplificator auto Mac Audio MPX 2000
putere:
4 ohmi, stereo: 2 x 60W RMS
2 ohmi, stereo: 2 x 80W RMS
4 ohmi, in punte: 1 x 150W RMS
THD < 0,05% (1 kHz)
SNR > 100 dB
4. Statie Magnat Edition Two Limited + subwoofer Magnat subtech 130 - **********/catalo...-two-limited.html - pret 500
5. Magnat B30 bass pack (subwoofer + amplificator) ***********/produ...on_B30_Bass_Pack/ - pret 530
mplificator Magnat Edition Two
amplificator stereo, 2 canale
putere:
4 ohmi, stereo: 2 x 55 W RMS
4 ohmi, in punte: 1 x 150 W RMS
2 ohmi, stereo: 2 x 75 W RMS
stabila la 2 ohmi
raspuns in frecventa: 5 Hz - 50 kHz (-3dB)
bass boost variabil 0 - 12 dB la 45 Hz
filtru low pass variabil 40 - 300 Hz (12 dB)
filtru high pass variabil 40 - 300 Hz (12 dB)
selector mod de functionare 2/1 canale
circuit de protectie impotriva scurtcircuitelor si a supraincalzirii
Subwoofer Magnat Edition B30
subwoofer de tip sealed cu difuzor de 30cm
putere: 250W RMS (800W max)
raspuns in frecventa: 25-250 Hz
SPL: 91 dB
impedanta 4 ohmi
greutate: 11kg
dimensiuni: 430 x 390 x 355/ 265 mm
Ps. am inteles ca Magnat este firma mai ieftina a marcii Mac audio. Asa este?
As vrea unul din cele 5, dar care sa se simta pe masina cu portbagaj separat ... va multumesc antifipat pentru o eventuala parere care m-ar putea ajuta.
Considerati ca un bass reflex e mai bun decat o incinta de tip sealed (fara nicio gaura) sau decat una de tip tub ?!
