d curand am achizitionat un amplif audison lrx 4.1 k si l am montat in urmatoarea configuratie: 2 canale punte si dau intr un pioneer d 1000 w rms cu 800 w, celelalte 2 canale alimenteaza 2 difuri infinity p componente!
PROBLEMA ACUM INCEPE: DUPA UN TIMP , DAK ASCULT LA VOL MARE SE APRINDE UNA DIN PROTECTIILE STATIEI!
IN MANUAL ACEEA PROTECTIE E DESCRISA K FIIND: AMP IN LIMITING .RARE OVERLOADS ACCURS. TURN OFF AMP TO RESET!
CAND SE APRINDE ACESTA PROTECTIE AMPLIFU NU SE OPRESTE CI FUNCTIONEAZA IN CONTINUARE SI DE ASEMENEA SI SUNETU, E ACELASI, ADIK NU DISTORSIONEAZA SAU ALTCEVA!O SG DATA S A INTRERUPT PUTIN !
IMPEDANTELE SUNT URMATOARELE : DIFURILE SUNT P 4 OHMI, IAR SUBW P 2 OHMI!
DE CE SE INTAMPLA CHESTIA ASTA?DC SE APRINDE PROTECTIE? ASA E NORMAL?EA D FAPT PALPAIE!
INAINTE SA AMPLIFIC SI BOXELE AM MERS DOAR CU SUBW SI N AM AVUT PROBLEME!SA SCADA DOAR IMPEDANTA BOXELOR?LE AM MAI AVUT AMPLIFICATE DAR CU UN INFINITY SI AT AU MERS PERFECT1ADIK ACEL AMPLIF NU INTRA IN PROTECTIE?
DATI MI UN SFAT DE AJUTOR!
MULTUMESC SI SPER K M AM ADRESAT SI POSTAT UNDE TREBUIE!
