-   EMMA (https://forum.4tuning.ro/372-emma.html)
-   -   need help cu audison !!! face probleme !!! (https://forum.4tuning.ro/372-emma/42293-need-help-audison-probleme.html)
tatae 27-05-07 16:23
d curand am achizitionat un amplif audison lrx 4.1 k si l am montat in urmatoarea configuratie: 2 canale punte si dau intr un pioneer d 1000 w rms cu 800 w, celelalte 2 canale alimenteaza 2 difuri infinity p componente!
PROBLEMA ACUM INCEPE: DUPA UN TIMP , DAK ASCULT LA VOL MARE SE APRINDE UNA DIN PROTECTIILE STATIEI!
IN MANUAL ACEEA PROTECTIE E DESCRISA K FIIND: AMP IN LIMITING .RARE OVERLOADS ACCURS. TURN OFF AMP TO RESET!
CAND SE APRINDE ACESTA PROTECTIE AMPLIFU NU SE OPRESTE CI FUNCTIONEAZA IN CONTINUARE SI DE ASEMENEA SI SUNETU, E ACELASI, ADIK NU DISTORSIONEAZA SAU ALTCEVA!O SG DATA S A INTRERUPT PUTIN !
IMPEDANTELE SUNT URMATOARELE : DIFURILE SUNT P 4 OHMI, IAR SUBW P 2 OHMI!
DE CE SE INTAMPLA CHESTIA ASTA?DC SE APRINDE PROTECTIE? ASA E NORMAL?EA D FAPT PALPAIE!
INAINTE SA AMPLIFIC SI BOXELE AM MERS DOAR CU SUBW SI N AM AVUT PROBLEME!SA SCADA DOAR IMPEDANTA BOXELOR?LE AM MAI AVUT AMPLIFICATE DAR CU UN INFINITY SI AT AU MERS PERFECT1ADIK ACEL AMPLIF NU INTRA IN PROTECTIE?
:shock:
DATI MI UN SFAT DE AJUTOR!
MULTUMESC SI SPER K M AM ADRESAT SI POSTAT UNDE TREBUIE!
saxo 27-05-07 18:36
Re: need help cu audison !!! face probleme !!!
Dupa cum spune si in carte, amplificatorul e in suprasarcina. Lasa sensibilitatea ma jos la partea de sub si gata.
tatae 28-05-07 01:27
adik?poti fi mai explicit?
sa l las mai incet? sau sa umblu la frecventa?
la c te referi?
saxo 28-05-07 05:54
Il lasi mai incet.
tatae 28-05-07 20:00
ok1 am inteles! de fapt din sub era toata chestia si anume din cauza incintei necorespunzatoare(prea mica)!
multumesc d ajutor!
tatae 06-06-07 17:40
revin la c am scris mai sus!
aceeasi problema!
intra in protectie chiar dak am lasat subu mai jos aproape deloc si l am pus si in 8 ohmi!
am trecut la difurile amplificate d p fata si am scos intai filtrele! la fel!
apoi am scos si tweterele! la fel
am inebunit!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ns c sa mai fac!
sa fie difurile chiar atat d proaste sau are statia ceva? (infinity ref 6510 cs sunt difurile)
saxo 06-06-07 17:47
Trebuie vazut ce-i acolo.
dj81bas 24-06-07 23:43
cat de rau se incinge amplificatorul? pe caldurile astea nu ar fi de mirare sa intre in limitare mai ales daca este utilizat la volume mari.
bezz 25-06-07 00:45
postul e din mai, nu cred ca era canicula, si ampul e oricum la bazar la "superoferta" :D
am si eu un lrx poate stii :) dar pe caldurile astea nu mi-a intrat o data in protectie...si nu-l iert deloc. i-am pus si cooler mai nou...
cred ca problema e la infinity-urile alea sau a nimerit un amp cu probleme, desi am inteles ca audison CHIAR verifica marfa.
dj81bas 25-06-07 16:43
amplificatoarele Audison sunt amplificatoare f bune doar ca sunt si f pretentioase la instalare si la utilizare.
dj01fad 28-06-07 04:41
in primul rand lasa amplificatorul fara sarcina (scoate toate difuzoarele), si da cu semnal mare in el; daca tot intra in limitare, ia in considerare o proba cu alt HU. daca nu mai intra, atunci chiar ai vreo problema, ori la un difuzor ori la amplificator. acest amplificator este unul foarte vun si nu vred ca avea vreo problema de la sine. se intampla ceva acolo. mai fa ceva: ia un aparat de masura si masoara fiecare difuzor in parte, si vezi sa fie toate bobinele in regula.
tatae 07-03-08 21:05
Am Uitat D Topicu Asta!
Nu Audisonu Facea Probleme Ci Subw Care Avea O Bobina In Scurt!
Merci Pt Interes Si Gazduire
