Hobby & Pasiuni Comune
Cluburi
Cluburi
A.C.S. Speedline Motorsport
Bucuresti
rover 200(25) - Highman (George)
Highman
Rover 200(25)
Motor de pe Rover "Tomcat"
Type
2+2 FHC
Fixed-head coupé
Number of doors
3
Wheelbase
2550 mm
100.4 in
Track
-front
1475 mm
58.1 in
-rear
1470 mm
57.9 in
Height
1170 mm
53.9 in
Length:wheelbase ratio
1.67
Ground clearance
Kerb weight
1185 kg
2612 lb
Weight distribution
(Front)
Fuel capacity
55 litres
12.1
UK
Gal
14.5
US
Gal
Drag coefficient
0.320
Bore × stroke
84.50 mm × 89.00 mm
3.33 in × 3.5 in
Cylinders
S-4
Displacement
2 litre
1994 cc
(121.681 cu in)
Type
DOHC
Double overhead camshaft
Compression ratio
8.50:1
Fuel system
Lucas fuel inj.
Maximum power
(DIN)
199.7 PS (197.0 bhp) (146.9 kW)
@ 6100 rpm
Specific output
98.8 bhp/litre
1.62 bhp/cu in
Maximum torque
(DIN)
232.5 Nm (171 ft·lb) (23.7 kgm)
@ 2100 rpm
bmep
1465.2 kPa (212.5 psi)
Specific torque
116.6 Nm/litre
Maximum rpm
8000
Manufacturer
Rover
Code
T4
Main bearings
5
Coolant
Water
Bore/stroke ratio
0.95
Unitary capacity
498.5 cc/cylinder
Aspiration
Turbo
Compressor type
1 Garrett turbo
Intercooler
Air/Water
Catalytic converter
Y
0-50 mph (80 km/h)
0-60 mph
0-100 km/h
7.10 s
0-100 mph
80-120 km/h (50-70 mph) in top
Standing ¼mile
Standing km
Top speed
270 km/h
Engine alignment
Front
Drive
Transverse
Steering
FWD
Turns lock-to-lock
rack & pinion PAS
Suspension
10.20 m
front
I.MS.ARB.
rear
I.DW.ARB.
I
Independent
DW
Double wishbones
ARB
Anti-roll bar
Tyres
front
195/55 VR 15
rear
195/55 VR 15
Brakes F/R
Braked area
VeDi/Di-S-ABS
Ve
Ventilated
Di
Disc (Disk)
Dr
Drum
S
Servo-assisted
ABS
Anti-lock Braking System
Transmission
5M
Top gear ratio
0.71
Final drive ratio
4.20
RAC rating
17.7
>>CLUB ROVER-MG<<
ROVER 200 cu inima turbo benzina de "Tomcat" ...
ROVER 75 cdti....zi de zi.....
Highman
Send a private message to Highman
Find More Posts by Highman
28-11-08, 14:38
B11EAU
Re: rover 200(25) - Highman (George)
Salutari si bine ai venit printre noi!!!
P.S. : Il cheama George, dar e mai timid asa de felul lui si nu se prezinta... :P
B11EAU
Send a private message to B11EAU
Find More Posts by B11EAU
29-11-08, 09:11
3
Bigu
Moderators
VW
Competitor CNCA
hello george
Bigu
Send a private message to Bigu
Visit Bigu's homepage!
Find More Posts by Bigu
29-11-08, 12:05
4
mikafly
Hello George.....nu fii timid......abuzeaza tastatura...
mikafly
Send a private message to mikafly
Find More Posts by mikafly
29-11-08, 23:02
5
Highman
salutare la toata miscarea Speedline
...bine (ca) vam gasit...multumesc ca mati primit....
Highman
30-11-08, 21:54
6
Yackone
Peugeot Driver
Virtual Tuning
Freehand Design Usergroup
PEUGEOT
4Rally
Design Team
SKODA
VW
bun venit in echipa
Yackone
Send a private message to Yackone
Find More Posts by Yackone
Previous Thread
Next Thread
