rover 200(25) - Highman (George)
Rover 200(25)
Motor de pe Rover "Tomcat" Type 2+2 FHC Fixed-head coupé Number of doors 3 Wheelbase 2550 mm 100.4 in Track -front 1475 mm 58.1 in -rear 1470 mm 57.9 in Height 1170 mm 53.9 in Length:wheelbase ratio 1.67 Ground clearance Kerb weight 1185 kg 2612 lb Weight distribution (Front) Fuel capacity 55 litres 12.1 UK Gal 14.5 US Gal Drag coefficient 0.320 Bore × stroke 84.50 mm × 89.00 mm 3.33 in × 3.5 in Cylinders S-4 Displacement 2 litre 1994 cc (121.681 cu in) Type DOHC Double overhead camshaft Compression ratio 8.50:1 Fuel system Lucas fuel inj. Maximum power (DIN) 199.7 PS (197.0 bhp) (146.9 kW) @ 6100 rpm Specific output 98.8 bhp/litre 1.62 bhp/cu in Maximum torque (DIN) 232.5 Nm (171 ft·lb) (23.7 kgm) @ 2100 rpm bmep 1465.2 kPa (212.5 psi) Specific torque 116.6 Nm/litre Maximum rpm 8000 Manufacturer Rover Code T4 Main bearings 5 Coolant Water Bore/stroke ratio 0.95 Unitary capacity 498.5 cc/cylinder Aspiration Turbo Compressor type 1 Garrett turbo Intercooler Air/Water Catalytic converter Y 0-50 mph (80 km/h) 0-60 mph 0-100 km/h 7.10 s 0-100 mph 80-120 km/h (50-70 mph) in top Standing ¼mile Standing km Top speed 270 km/h Engine alignment Front Drive Transverse Steering FWD Turns lock-to-lock rack & pinion PAS Suspension 10.20 m front I.MS.ARB. rear I.DW.ARB. I Independent DW Double wishbones ARB Anti-roll bar Tyres front 195/55 VR 15 rear 195/55 VR 15 Brakes F/R Braked area VeDi/Di-S-ABS Ve Ventilated Di Disc (Disk) Dr Drum S Servo-assisted ABS Anti-lock Braking System Transmission 5M Top gear ratio 0.71 Final drive ratio 4.20 RAC rating 17.7 |
Re: rover 200(25) - Highman (George)
Salutari si bine ai venit printre noi!!!
P.S. : Il cheama George, dar e mai timid asa de felul lui si nu se prezinta... :P |
hello george :D
Hello George.....nu fii timid......abuzeaza tastatura...
salutare la toata miscarea Speedline:wave:...bine (ca) vam gasit...multumesc ca mati primit....:bong:....
bun venit in echipa;)
| All times are GMT +2. The time now is 07:03. |
