Go Back   Forum 4Tuning > Masini & Tuning > MASINA MEA > OPEL > Zona tehnica Opel
Zona tehnica Opel Zona tehnica, secrete, tips&tricks Opel
Old 14-11-04, 05:31   #1
catalin rs4
catalin rs4's Avatar
Default opel kadet gsi
ce puteti sami spuneit despre masina..asta..ma refer..la bubele ei..etc.miam luat un kadett gsi.2.0 115 cp pt romania ..nu prea ma pricep la opel..cam ce performante.etc..are asa un gsi?? scrieti tot ce este util aici..despre gsi va rog..
catalin rs4 is offline   Reply With Quote
Old 14-11-04, 11:54   #2
cioli17
cioli17's Avatar
[RR]
ba astia de pe carfolio is tampiti...ei dau 115 cp la motorul de 1.8... si la ala de 2.0 dau 130 cp...oricum fainutza masina destul de usoara ceea ce e bine ...are 2 usi... ...o sa strice mult mai repede ca rs4... apropo cat ai dat pe ea ?
sper ca ti-au fost bune detaliile despre masina
cioli17 is offline   Reply With Quote
Old 14-11-04, 13:00   #3
ffocus
ffocus's Avatar
Wheelbase: 2520 mm 99.21 in
Track front: 1406 mm 55.35 in
Track rear: 1406 mm 55.35 in
Length: 4000 mm 157.48 in
Width: 1663 mm 65.47 in
Kerb weight: 930 kg 2050.29 lb
Drag coefficient: 0.3
Frontal area: 1.9
Cx: 0.57
Manufacturer: Opel
Type: S-4
SOHC
8 valves total
2 valves per cylinder
Bore x stroke: 84.80mm × 79.50mm
Bore / stroke ratio: 1.07
Displacement: 1796 cc 109.59 cu in
Compression: 9.50:1
Fuel system: Bo L-Jet fuel inj.
Aspiration: Normal
Catalytic Converter: N
Max. output: 116.6 PS (115.0 bhp) (85.8 kW)@5800 rpm
Max. torque: 150.0 Nm (111 lbft) (15.3 kgm)@4800 rpm
Coolant: Water
Specific output: 64 bhp/litre
Specific torque: 83.52 Nm/litre
0-60mph: 9 s
0-100km/h: 9.5 s
Quarter mile: 16.80s
Top speed: 191 km/h
Power to weight: 123.66 bhp/ton
Engine location: Front
Engine alignment: Transverse
Suspension front: I.MS.ARB.
Suspension rear: I.TA.TB.CS.ARB.
Transmission: 5M
Drive: FWD
Final drive ratio: 3.94
motorul e super...am un prieten cu opel corsa gsi...rupe asfaltu...si la 140 cand da blana are putere
Hell is empty. All the Devils are here.
ffocus is offline   Reply With Quote
Old 14-11-04, 13:26   #4
Gabi
Super Moderator
Gabi's Avatar
Opel Kadett - motor 2000 cmc 16v + turbo = 205 (parca) cp. De ajuns, zic eu.
Gabi is offline   Reply With Quote
Old 14-11-04, 14:40   #5
catalin rs4
Default Re:
Frontal area: 1.9
Cx: 0.57
Manufacturer: Opel
Type: S-4
SOHC
8 valves total
Compression: 9.50:1
Aspiration: Normal
Coolant: Water
0-60mph: 9 s
0-100km/h: 9.5 s
Top speed: 191 km/h
Transmission: 5M
Drive: FWD
merci mult ffocus...oricum destul de bune performante.. masina ma costat undeva pe la 1000 acuma ii in service..pt tüv...etc..miercuri ii gata am sa bag si niste poze..curand...
Old 30-11-04, 10:48   #6
Sc0OTeR
Sc0OTeR's Avatar
[RR]
GSI de 2l si 116 cai are kat, cel fara kat are 129 si mai este si un motor de 1.8l tot de 116 cai (datele le ai de la ffocus).
Intrebai de bubele de la opel. In afara de rugina care este ceva normal la opel, daca ai compresie buna si pui ulei de calitate in el si daca proprietarul dinaintea ta nu a supraincalzit-o , te plictisesti de masina asta inainte sa se strice. Conditia e sa nu o forjezi inainte sa incalzesti motorul. Daca numai ce ai pornit-o si ii dai blana o sa o omori. In concluzie, daca ai putina grija de motor, mergi cu ea pana te saturi. Sper ca te-am ajutat cu ceva
Cam cati km are a ta
Sc0OTeR is offline   Reply With Quote
Old 30-11-04, 10:53   #7
Sc0OTeR
Sc0OTeR's Avatar
[RR]
Si inca ceva: cumpara-ti cat mai esti in Germania o curea de distributie noua ca e foarte importanta si de montat poti sa o pui in romania sau in germania daca o poti pune mai ieftin. Mai bine o si pui in germania ca sa nu ai evenimente pe drumul spre \"patria-mama\"
Old 30-11-04, 11:07   #8
catalin rs4
Default Re:
curea am luat una noua... daca ii scot katu afara oare merge mai bine atunci? oricum merge si acuma destul de bine si dau non stop in ea blana!!!
Old 30-11-04, 11:19   #9
Sc0OTeR
Sc0OTeR's Avatar
[RR]
Din cate stiu eu, la motorul de 1.6 mecanicii de la opel nu recomanda scoaterea katului pentru ca tot motorul este reglat pentru kat, daca il scoti trebuie sa faci si alte modificari, banuiesc ca si la motorul de 2l e la fel La Ascona mea unchiu-miu i-a scos katul si zice ca nu a simtit nici o diferenta, deci e mai indicat sa il lasi pe masina. Daca insisti sa il scoti, cauta un mecanic de la opel care se pricepe la asa ceva ca risti sa ai probleme dupa aia. Eu iti recomand sa il lasi pe masina, dar decizia e a ta. Si monteaza cureaua aialalta ca risti sa se rupa asta(cureaua la opel se schimba pe la 60000 de km). Cati km are masina Stii de cati km a schimbat fostul proprietar cureaua
Old 30-11-04, 11:33   #10
catalin rs4
masina are 177000 originali din cate stiu eu... merge brici oricum nam luat masina sa bag bani inea...o las asa cum ii..mai pus pe ganduri acuma cu cureaua..aia
Old 30-11-04, 11:55   #11
Gabi_323i
Gabi_323i's Avatar
pune 16v
Gabi_323i is offline   Reply With Quote
Old 30-11-04, 12:10   #12
catalin rs4
Default Re:
Originally Posted by \"B 31 FXN\"
pune 16v
bah esti nebun? crezi ca nam ce face cu bani? am luat masina sa o rup in tara nu sa bag bani in ea...
Old 30-11-04, 12:11   #13
Gabi_323i
Gabi_323i's Avatar
ce ma e asa de scump un 16v acolo?
Old 30-11-04, 12:15   #14
Sc0OTeR
Sc0OTeR's Avatar
[RR]
Moturul de 16v are jumatate din viata unui motor cu 8v. Ti-am spus de curea ca ar fi pacat sa ai vreo problema tocmai acuma cu ea si ti-as recomanda sa dai blana dupa ce schimbi cureaua ca daca cedeaza asta nu mai faci nici 5 metri cu masina
Apropo, ce se mai aude de pozele alea
Old 30-11-04, 12:16   #15
Gabi_323i
Gabi_323i's Avatar
chiar la opel vin pistoanele in supape?
