am probleme la un golf 4 1.6 i 105cp la emisii,,,, imi ramane aprins becul galben cu forma de motor,,in bord!!stie cineva cum as pute a face sa l repar,,,,,ce tre sa fac??elp me!! [email protected]
Member of: [AfterDark Racing] [FORD] [DACIA] [4Tuning International]
Re: probleme la emisii
Engine warning light
If the engine warning light illuminates with the engine running, it indicates a malfunction.
If the engine warning light flashes when driving, reduce the vehicle speed immediately. If it continues to flash, avoid heavy acceleration and high engine speed.
Have your vehicle checked by an expert immediately.
Cam asta scrie intr-un manual de Ford despre problema ta.
... verifica masa de pe motor... la unele modele aceasta este prea scurta si din vibratiile motorului se sectioneaza ramanand doar invelisul de plastic. fara masa pe motor apar disfunctii in citirea datelor de la diferiti senzori... bafta!
'02 citroen xsara coupe 1.9 D
'78 ford granada 2.0 V6 (intrat in reparatie capitala)
