Old 07-05-18, 17:02   #1
masterkillcc
Default Probleme Passat CC
Salut tuturor,
Am intampinat urmatoarele probleme ca urmarea unor lucrari pe masina, scriu in ordinea evenimentelor:
Am inlocuit toate 4 amortizoare, placutele frana spate, intreg kit-ul de ambreiaj (volanta, pompa etc.) toate bucsele si bieletele pe fata inclusiv bascule, in tot timpul acesta bateria a fost deconectata (data jos).
Dupa ce a fost gata toata treaba imi da eroare frana de mana (am in bord martorii aprinsi inclusiv cel de ACC pe portocaliu cat si butonul care se aprinde on/off portocaliu) si nu imi mai functioneaza nici xenonul directional (nu se mai autoregleaza la pornire) si bat cam 3-4 metri...in vcds imi da urmatorile erori: (precizez ca eu nu sunt expert in vcds):
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 230
Mileage: 216056 km
Time Indication: 0
Date: 2013.14.20
Time: 08:07:46
5 Faults Found
02429 - Right Parking Brake Motor (V283) Clamping Force Not Reached
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 9
Mileage: 215845 km
Time Indication: 0
Date: 2013.14.18
Time: 09:16:21
Freeze Frame:
Voltage: 11.90 V
Count: 3
Speed: 0.0 km/h
Hex Value: 0x12E1
Hex Value: 0x0001
Hex Value: 0x1008
03200 - Switch for Electric Parking Brake (E53
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 6
Reset counter: 9
Mileage: 215845 km
Time Indication: 0
Date: 2013.14.18
Time: 09:16:23
Freeze Frame:
Voltage: 11.70 V
Count: 10
Speed: 0.0 km/h
Hex Value: 0x12F0
Hex Value: 0x0001
Hex Value: 0x1004
02433 - Supply Voltage for Right Parking Brake Motor (V283)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 9
Mileage: 215845 km
Time Indication: 0
Date: 2013.14.18
Time: 00:31:32
Freeze Frame:
Voltage: 12.70 V
Count: 23
Speed: 0.0 km/h
Hex Value: 0x12F0
Hex Value: 0x0001
Hex Value: 0x1002
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11101011
Fault Priority: 2
Fault Frequency: 26
Reset counter: 230
Mileage: 215845 km
Time Indication: 0
Date: 2013.14.18
Time: 00:23:11
Freeze Frame:
Voltage: 12.00 V
Count: 30
Speed: 0.0 km/h
Hex Value: 0x1271
Hex Value: 0x0001
Hex Value: 0x1010
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 2
Reset counter: 9
Mileage: 215845 km
Time Indication: 0
Date: 2013.14.18
Time: 09:16:23
Freeze Frame:
Voltage: 11.70 V
Count: 42
Speed: 0.0 km/h
Hex Value: 0x12F0
Hex Value: 0x0001
Hex Value: 0x1004
masterkillcc is offline   Reply With Quote
