Re: Salutare probleme papuc 1.9 D
poti pune unul din motoarele seria f pe motorina
The F8x is the indirect injected Diesel version and has an 8-valve SOHC architecture, it uses precombustion chambers achieve the required air/fuel mixing.
Applications:
F8M 1.6 L (1,595 cc or 97 cu in), B x S: 78.0 by 83.5 millimetres (3.07 in Χ 3.29 in).
19851989 Renault R11
19851989 Renault R9
1985 Renault R5 Super 5
1986 Renault Extra
F8Q 1.9 L (1,870 cc or 114 cu in), B x S: 80.0 by 93.0 millimetres (3.15 in Χ 3.66 in).
1986 Renault Extra
19882000 Renault R19
19901995 Renault R21
19911997 Renault Clio
19952002 Renault Mιgane
19962003 Renault Scιnic
19972001 Renault Trafic
19941998 Mitsubishi Carisma
19941996 Volvo 440/460
19952004 Volvo S40/V40
20022006 Dacia Pick-Up
20032005 Dacia Solenza
sau
The F9x is the direct injected Diesel version and also features an 8-valve SOHC configuration, it has swirl generating intake ports to create swirling (vortex) of the aspirated air, and either a torodial- or an elsbett- piston bowl to twist te injected fuel vapour, also to achieve the required air/fuel mixing. The diesel-fuel is delivered either by a mechanical injection pump or a common rail fuel injection installation.
Applications:
F9Q 1.9 L (1,870 cc or 114 cu in), B x S: 80.0 by 93.0 millimetres (3.15 in Χ 3.66 in).
19962002 Renault Espace
19972010 Renault Master
19972001 Renault Laguna I
19982004 Mitsubishi Carisma
19982004 Volvo S40
20012005 Renault Laguna II
2005 Suzuki Grand Vitara
