Old 01-10-10, 00:35   #1
cristy_dre2003
cristy_dre2003's Avatar
Default e36 service manual
salutare la toata lumea. am cautat sa vad daca a mai pus cineva manualul de la e36 si nu am gasit asa ca il pun eu. sper sa va ajute
cristy_dre2003 is offline   Reply With Quote
Old 02-11-10, 10:38   #2
marchisionutz
Default Re: e36 service manual
e36 316i nu ai manual..k in al tau e doar de la 318 in sus...
marchisionutz is offline   Reply With Quote
Old 02-11-10, 17:25   #3
cristy_dre2003
nu am dar care e marea diferenta intre M40b16 si M40b18 cu exceptia cilindreei. sau dupa caz M43b16 si M43b18.
Old 09-03-11, 02:00   #4
Fabrizzio
Va salut baieti!am o problema...am un 320i E36 si vreau sa-i pun 2.8,dar masina pe care am gasit-o pt a-mi dona motorul este automata.vreau sa stiu daca,cutia pe care o am eu merge pe 2.8?
Fabrizzio is offline   Reply With Quote
Old 09-03-11, 09:49   #5
maxmartinez
maxmartinez's Avatar
salut, din cate stiu eu nu e aceeasi cutie, tu ai la 320 Gertrag 250 iar la 2.8 e ZF 320, acum nu stiu daca merge adaptata ptr motorul de 2.8.
Part 23001434485 (Rmfd-5 speed gearbox) was found on the following E36 vehicles:
E36 328i Convertible, M52, AUTO (BK83) : Manual Transmission S5D...Z
E36 328i Convertible, M52, MANUAL (BK73) : Manual Transmission S5D...Z
E36 328i Coupe, M52, AUTO (BG23) : Manual Transmission S5D...Z
E36 328i Coupe, M52, MANUAL (BG13) : Manual Transmission S5D...Z
E36 328i Sedan, M52, AUTO (CD23) : Manual Transmission S5D...Z
E36 328i Sedan, M52, AUTO (CD43) : Manual Transmission S5D...Z
E36 328i Sedan, M52, MANUAL (CD33) : Manual Transmission S5D...Z
E36 328i Sedan, M52, MANUAL (CD13) : Manual Transmission S5D...Z
E36 M3 Convertible, S52, AUTO (BK03) : Manual Transmission S5D...Z
E36 M3 Convertible, S52, MANUAL (BK93) : Manual Transmission S5D...Z
E36 M3 Coupe, S50, AUTO (BF03) : Manual Transmission S5D...Z
E36 M3 Coupe, S50, MANUAL (BF93) : Manual Transmission S5D...Z
E36 M3 Coupe, S52, MANUAL (BG93) : Manual Transmission S5D...Z
E36 M3 Sedan, S52, AUTO (CD03) : Manual Transmission S5D...Z
E36 M3 Sedan, S52, MANUAL (CD93) : Manual Transmission S5D...Z
maxmartinez is offline   Reply With Quote
Old 02-08-11, 17:13   #6
roky28
salut aceeasi treaba vreau sa fac si eu..ai reusit pana la urma?
roky28 is offline   Reply With Quote
Old 05-01-12, 00:22   #7
branescu
Default salut
salutare...am si eu o problema cu un 318is sedan...cand vreau so pornesc chitzaie si dupaia o ia...ma puteti ajuta ?nam idee de la ce face asa
branescu is offline   Reply With Quote
Old 05-01-12, 00:26   #8
cristy_dre2003
Default Re: salut
318is sedan? cam rare astea. porneste si chitaie cateva secunde(mai multe) sau intai chitaie si apoi porneste? in prima situatie poate sa fie cureaua la accesorii. in a doua situatie nu stiu ce sa zic
Old 12-09-12, 10:11   #9
alexxss
alexxss's Avatar
merge montata cutia dar nu o sa reziste la cuplu motorului de 2.8. doar daca vrei sa faci ceva provizoriu.
alexxss is offline   Reply With Quote
Old 07-02-14, 18:06   #10
St3fann
salut am si eu o mica problema, am un e36 din 94 si iam schimbat antigelul acum ceva timp in urma iar dupa ce am mersc circa 150 de km in aceeasi zi am ajuns acasa lam oprit si dupa vreo ora cand am vrut sa plec iar mi sa cuplat vascocuplajul si nu se mai decupleaza merge ca si cum ar fi motorul supraincalzit. va rog ajutatima cu vrun sfat ceva sa nst ce pot sa ii fac?
St3fann is offline   Reply With Quote
Old 07-02-14, 18:15   #11
St3fann
nimic nimeni nici o parere?
Old 14-06-14, 12:18   #12
Paul_ToNy
Paul_ToNy's Avatar
Rog pe cei care stiu sau au Service manual e36 pentru 316i 1995 sa il puna aici , am cautat peste tot si nu am gasit nicaieri , am gasit 316i dar 1998 si nu stiu daca este acelasi cu cel din 1995
E36_Sedan_Coupe after 93.pdf
ce am atasat eu e doar sistemul electric dar caut service manual care sa fie si pentru 316i nu cum a postat alt coleg care era de la 318 in sus nu stiu de ce dar in titlu apare after 93 dar in pdf apare doar 1998 !?! poate e la fel si de aceea , poate stie cineva
My Car
Paul_ToNy is offline   Reply With Quote
Old 01-05-15, 02:21   #13
dudu27
dudu27's Avatar
Salutare lume am si eu nevoie va rog de ajutor.Am un BMW e36 316 din 95 si nu stiu ce are de la un timp cand o accelerez da semne ca se ineaca si ca vrea sa se opreasca.I-am schimbat bujiile si fisele si degeaba.Ma poate ajuta cineva va rog.Stima si multumesc
dudu27 is offline   Reply With Quote
Old 07-05-15, 15:28   #14
dudu27
dudu27's Avatar
are cinva idee la ce am scris va rog
