e36 service manual
salutare la toata lumea. am cautat sa vad daca a mai pus cineva manualul de la e36 si nu am gasit asa ca il pun eu. sper sa va ajute
Re: e36 service manual
nu am dar care e marea diferenta intre M40b16 si M40b18 cu exceptia cilindreei. sau dupa caz M43b16 si M43b18.
Va salut baieti!am o problema...am un 320i E36 si vreau sa-i pun 2.8,dar masina pe care am gasit-o pt a-mi dona motorul este automata.vreau sa stiu daca,cutia pe care o am eu merge pe 2.8?
Part 23001434485 (Rmfd-5 speed gearbox) was found on the following E36 vehicles: E36 328i Convertible, M52, AUTO (BK83) : Manual Transmission S5D...Z E36 328i Convertible, M52, MANUAL (BK73) : Manual Transmission S5D...Z E36 328i Coupe, M52, AUTO (BG23) : Manual Transmission S5D...Z E36 328i Coupe, M52, MANUAL (BG13) : Manual Transmission S5D...Z E36 328i Sedan, M52, AUTO (CD23) : Manual Transmission S5D...Z E36 328i Sedan, M52, AUTO (CD43) : Manual Transmission S5D...Z E36 328i Sedan, M52, MANUAL (CD33) : Manual Transmission S5D...Z E36 328i Sedan, M52, MANUAL (CD13) : Manual Transmission S5D...Z E36 M3 Convertible, S52, AUTO (BK03) : Manual Transmission S5D...Z E36 M3 Convertible, S52, MANUAL (BK93) : Manual Transmission S5D...Z E36 M3 Coupe, S50, AUTO (BF03) : Manual Transmission S5D...Z E36 M3 Coupe, S50, MANUAL (BF93) : Manual Transmission S5D...Z E36 M3 Coupe, S52, MANUAL (BG93) : Manual Transmission S5D...Z E36 M3 Sedan, S52, AUTO (CD03) : Manual Transmission S5D...Z E36 M3 Sedan, S52, MANUAL (CD93) : Manual Transmission S5D...Z |
salut
salutare...am si eu o problema cu un 318is sedan...cand vreau so pornesc chitzaie si dupaia o ia...ma puteti ajuta ?nam idee de la ce face asa
Re: salut
salut am si eu o mica problema, am un e36 din 94 si iam schimbat antigelul acum ceva timp in urma iar dupa ce am mersc circa 150 de km in aceeasi zi am ajuns acasa lam oprit si dupa vreo ora cand am vrut sa plec iar mi sa cuplat vascocuplajul si nu se mai decupleaza merge ca si cum ar fi motorul supraincalzit. va rog ajutatima cu vrun sfat ceva sa nst ce pot sa ii fac?:sad:
nimic nimeni nici o parere?:sad:
Rog pe cei care stiu sau au Service manual e36 pentru 316i 1995 sa il puna aici , am cautat peste tot si nu am gasit nicaieri , am gasit 316i dar 1998 si nu stiu daca este acelasi cu cel din 1995
Attachment 2996586 ce am atasat eu e doar sistemul electric dar caut service manual care sa fie si pentru 316i nu cum a postat alt coleg care era de la 318 in sus nu stiu de ce dar in titlu apare after 93 dar in pdf apare doar 1998 !?! poate e la fel si de aceea , poate stie cineva |
Salutare lume am si eu nevoie va rog de ajutor.Am un BMW e36 316 din 95 si nu stiu ce are de la un timp cand o accelerez da semne ca se ineaca si ca vrea sa se opreasca.I-am schimbat bujiile si fisele si degeaba.Ma poate ajuta cineva va rog.Stima si multumesc
are cinva idee la ce am scris va rog
| All times are GMT +2. The time now is 02:58. |
