Old 04-01-12, 12:55   #1
e36325i
e36325i's Avatar
Red face Se pot inlocuii internele de la un grup carcasa mare de e36 cu internele de e34 ?
e36325i is offline   Reply With Quote
Old 05-01-12, 08:20   #2
JustinCase
JustinCase's Avatar
Default Re: Se pot inlocuii internele de la un grup carcasa mare de e36 cu internele de e34 ?
Nu exista model de E36 sa aiba carcasa mare din fabrica, probabil de referi la carcasa medie de 188mm care intradevar are "miezul" interschimbabil cu cel de E34 tot de 188mm.
Ca informatie diversa, carcasa mare de E34 are 210mm si se gaseste doar pe M5 sau V8
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you."
Old 05-01-12, 10:45   #3
e36325i
e36325i's Avatar
Stiu la ce te referi am zis carcasa mare ca asa e uzual vorbind intre posesorii de e36 in fine deci ar merge internele de pe un grup de e34 carcasa medie in carcasa de e36 325i non vanos ??? mersi de ajutor
Old 12-01-12, 22:03   #4
the_rifle
Da. Se poate. Conteaza cine ti-l face sa-l faca bine altfel iti huruie...
